Need help on decision to swap axles - JeepForum.com
post #1 of 7 Old 11-03-2013, 04:28 PM Thread Starter
jerry81
My current axles are 30/35 with 3.07 gears I believe. I have an 89 yj with the 4.2 engine and ax-15 tranny. I have 33" tires on and love them but I can't use fith gear anymore. Should I find a set of 4cyl axles to get the 4.10 gear ratio? Please advise.
jerry81 is offline
post #2 of 7 Old 11-03-2013, 05:03 PM
idskot
You should have 3.55 gears, not 3.07. The 3.07 is usually for the inline-6 automatics. 3.55 is usually for the inline-6 manuals, 3.73 (or whatever it is) is for auto inline-4's, and the 4.10's were used with the inline-4 manuals.
Now, I had 3.07's with a 4.0L and used 33" tires. When I swapped my Dana-35 to a Ford 8.8, I switched it from 3.07's to 4.10's. And I absolutely loved the transformation. It accelerated like an actual car and not like a '84 Corolla.
My advice: If you're going to regear, I would most certainly just replace your Dana 35 with a Ford 8.8. I bought mine for $250, I got the mounting hardware for another $150 or so, had it welded on and I couldn't be happier.
As for the front... if you plan on doing the regear yourself and have a full solid weekend to dedicate to regearing the front [as well as a lot of time to research, read, and research some more], then I say get the kit. They're about $250 bucks, and it comes with a new ring, a new pinion, new bearings and new shims.
However! YOU WILL NEED A NEW CARRIER! I can't stress this enough, as I forgot I needed one, and I ended up ****ing up my brand new gears.
The proper carrier is, I believe around $80 bucks. Now, you should most certainly check your areas junk yards for possible swaps out of manual inline-4's. Rather than regearing myself once more, I decided to get a whole axle for $400 dollars. It came with a spare set of brake calipers, spare axle shafts, spare knuckles, spare cover, etc. You end up getting a lot of things you can use later on (if you have the room and the desire to store them).
It also makes everything much easier. Where as before you had to set up everything, this is just drop your front springs, remove old axle, put in new axle. Fin.
That's just my $.02
Recap: My advice is to not touch the Dana 35, and to upgrade the rear to a Ford 8.8. (The Ford 8.8 is much stronger than the Dana 35, and even stronger than the Dana 44. The best matching Ford 8.8 is out of early 2000's Ford Explorers. Some even have LSDs.)
If you plan on doing the regear yourself, you can get a kit but remember to get a carrier that will fit the gears. If you want to, you can also replace the whole front axle and get spare parts.
If you plan on paying someone to regear, I've heard some people get quoted $1200 dollars. But I can't say for certain how much it is for someone to regear your axles.
idskot is offline
post #3 of 7 Old 11-03-2013, 05:05 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You have 3.07. Swap to 4.10
Luck Favours The Prepared
Anticanman is offline
post #4 of 7 Old 11-03-2013, 06:47 PM
bill8bud
You could also look for a front Dana 30 from a 4 banger it should be a 4.10 only thing to watch for is the knuckles are different they changed in the 92 model I believe.
bill8bud is offline
post #5 of 7 Old 11-04-2013, 06:10 AM
jason280
Every 6cyl manual I've owned had 3.07 stock gears. Like its been mentioned, best bet would be to go with 4.10s. I pulled a 4.10 D30 from a 4cyl, and I'm running a 4.10 8.8 in the rear.
None
jason280 is offline
post #6 of 7 Old 11-04-2013, 08:41 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
x2
Much easier to swap in a 4 cyl axle than to regear your existing d30. Tons of info on 8.8 swaps on the forum.
Randonexplosion is offline
post #7 of 7 Old 11-04-2013, 08:57 AM
zeus87gn
1987 YJ Wrangler
The old fashioned carbed 4.2 turning 33" tires would only need 3.73 gears
I was told this long ago by a Jeep expert that had been around them all his life
I was talked into 4.10s when I finally did re-gear a couple of years ago
The 4.10s are nice (as I am running them now) but I rarely use 1st and wish I had a 6th gear for the highway
Since I already have my Jeep set up like this, I will be going 35s in the future
If the OP had a 4.0l, then yes - 410s are just fine
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
