Need help clutch problems - JeepForum.com
post #1 of 4 Old 09-05-2011, 04:47 PM Thread Starter
jlegan
I installed a master cylinder, slave cylinder, clutch, and had flywheel resurfaced. I got it back together bled system and went to back it out and it will not go into gear. I do not know what else to do, I was told that since i resurfaced flywheel i will need a spacer. Any help would be appreciated
jlegan is offline
post #2 of 4 Old 09-06-2011, 09:32 AM
Que89YJ
Bump it for the first shift for you. I don't have a clue but I know there are others that do and I can sense your frustration.
Que89YJ is offline
post #3 of 4 Old 09-06-2011, 10:49 AM
dank
Hi,
Can you be more specific on the symptoms: does it grind when you try to put it in gear? does the gear shift lever move into first gear but you don't have traction when you release the clutch?do you have proper pressure when you press on the clutch pedal? Is your transfer case in neutral?
dank is offline
post #4 of 4 Old 09-06-2011, 11:00 AM
Kamikaze
Also be more specific on how the clutch pedal feel compare to before it was changed. Will it shift with engine off (this is to rule out tranny issue). Have you bleed out all the air from master cylinder to slave cylinder?
Also you shouldn't need any spacer. the Pressure plate bolt right up to the flywheel (make sure you torque it right).
Good luck.
Live Free, Laugh Loud and be Friendly.
Kamikaze is offline
Clutch problems Please Help medic10679 YJ Wrangler Technical Forum 6 02-18-2011 10:11 AM
Clutch problems Excent YJ Wrangler Technical Forum 2 12-03-2010 03:51 PM
clutch problems Unii YJ Wrangler Technical Forum 2 04-07-2010 12:06 PM
clutch problems "double clutch shifting" propkillr YJ Wrangler Technical Forum 4 07-11-2009 12:08 PM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
