need help- can't find engine mount brackets - JeepForum.com
post #1 of 11 Old 11-17-2009, 02:32 PM Thread Starter
YJ2DAMX
i started my 2.5 to 4.0 swap. called the dealership to get the motor mount brackets and i was told that they are no longer produced and that there is only a right side mount availble. anyone know where else i can get them or what they are refered to so i can find them.
Gotta PAY to PLAY
YJ2DAMX is offline
post #2 of 11 Old 11-17-2009, 02:35 PM
ritjobbie
Brown Dog Offroad
Quality.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #3 of 11 Old 11-17-2009, 03:30 PM
Boodyrider
Second. BD makes both a stock replacement type and a seriously overbuilt version. I got the overbuilt version and love 'em
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #4 of 11 Old 11-18-2009, 10:16 AM Thread Starter
YJ2DAMX
im trying to find the brackets that those mounts would bolt to on the frame. the ones that are welded on.
Gotta PAY to PLAY
YJ2DAMX is offline
post #5 of 11 Old 11-18-2009, 10:19 AM
texas_yj
you could very easily make some out of a 1 foot piece of 2x2 heavy wall box tubing, cut a 45* angle on the motor side and cut the bottom out so they are 'U' shaped, I you need, I'll go measure the length from tip to frame for ya.
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #6 of 11 Old 11-18-2009, 11:01 AM
idaholtby
Last I knew, these are still BOTH available from the dealer. I suspect the dealer was confused when you inquired about them. The brackets that bolt to the motor, only the right side is still available like they told you. I believe they may have confused the block mount brackets with the frame weld on mounts/perches.
idaholtby is offline
post #7 of 11 Old 11-18-2009, 02:11 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Might be able to find someone or a shop that is planning/has started a SBC conversion and get the ones they cut off.
5.7YJ is offline
post #8 of 11 Old 11-18-2009, 06:29 PM Thread Starter
YJ2DAMX
i will call my local dealer tomorrow and find out. also i would like to know the length cause i had originally thought about fabing up my own but changed plans after reading a couple threads
Gotta PAY to PLAY
YJ2DAMX is offline
post #9 of 11 Old 02-16-2013, 09:29 PM
rgarza203
The dealer no longer carries them, believe me after numerous calls of frustration. I called brown dog jeep and they directed me to AMC 4x4 in phoenix. They located them and removed from a crapy frame. They were only 70 bucks, had to clean them up at the welders shop but basically saved my jeep.
rgarza203 is offline
post #10 of 11 Old 02-16-2013, 09:35 PM
Mark05059
you do realize that they thread you just posted to was 4 years old?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 11 Old 02-16-2013, 10:07 PM
slmason72
After 4 years of calling around, I can understand his frustration.
slmason72 is offline
YJ 2.5 Engine mount brackets Cyberknox YJ Wrangler Technical Forum 24 06-22-2015 02:16 AM
Frame to Engine Mount Brackets Whitey2001 YJ Wrangler Technical Forum 6 02-01-2013 07:25 AM
where can I find these brackets spizarxxx TJ Wrangler Technical Forum 9 02-25-2009 08:21 PM
4.0 engine mount brackets critters YJ Wrangler Technical Forum 2 05-04-2003 07:41 PM
Where can I find 4x6 speaker brackets kgoode80 TJ Wrangler Technical Forum 6 05-29-2002 04:22 PM
