Need help with busted NP 231 - JeepForum.com
post #1 of 11 Old 03-26-2012, 03:28 PM Thread Starter
gunnabemarine
1987 YJ Wrangler
I have an 87 yj 4.2 L with the BA10/5 tranny and np 231 T-case. One day I was accelerating from a stop when the rear driveshaft broke lose and started violently thrashing. I immediately pulled over, and looked underneath to find it was bleeding t-case fluid everywhere. After closer inspection I found that the rear U-joint somehow fell apart, and the torque of the flailing driveshaft cracked the t case.
Anyway now I'm working on getting a new T-case, and am having a difficult time. If I could find a good deal on a newer AX15 with 231, I might take that opportunity. The problem I see with that is that all the AX15 with 231s I'm finding at the junkyard have electronic speedos. Does anyone know how I could make a conversion between a mechanical speedo and the new ones? If I do end up just getting a tcase, does anyone know the years that would be directly compatible with the BA 10/5? There are plenty of cherokees at the junkyard but I'm just not sure of compatibility. Any answers or advice would be much appreciated.
gunnabemarine is offline
post #2 of 11 Old 03-26-2012, 03:30 PM
Mark05059
the speedometer adapter from your transfer case will swap over to the new electronic ones. Its a 1 bolt and clamp to remove it and then just needs to be clocked correctly in the new transfer
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 11 Old 03-26-2012, 03:37 PM Thread Starter
gunnabemarine
1987 YJ Wrangler
So that would allow me to go newer with a transfer case, accept with the input shaft problem, I believe the BA10/5 has a 19 spline, whereas the AX15 has 21 spline. Any idea on that conversion? Also how would I clock the new transfer case?
Thanks a lot!
post #4 of 11 Old 03-26-2012, 04:25 PM
roadyrob
1987 YJ Wrangler
find one from a 4 cyl, it will work.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #5 of 11 Old 03-26-2012, 05:08 PM
ourlee
i have a 4 cyl tcase for sale actually. pm me if you want. i'm in NJ came out of a YJ 4 cyl S. perfect shape.
2001 TJ 4.0 auto
ourlee is offline
post #6 of 11 Old 03-26-2012, 08:56 PM
jamesbland123
1987 YJ Wrangler
The BA10 has a 21 spline and the AX15 has 23 spline. If you are getting an AX15 with transfer case then you don't need to do anything for input shaft. But if you only get the NP231 then to mate it up with that BA10 you'll need to convert it from 23 to 21 spline.
If you upgrade to the AX15 make sure you get the external clutch slave cylinder. You'll also want the bell housing.
For the Speedo cable, just remove the housing and put this in your new NP231 case. You might have to swap speedo gears as the one you have is a long shaft and the newer NP231 may use a short shaft.
jamesbland123 is offline
post #7 of 11 Old 03-27-2012, 06:15 AM Thread Starter
gunnabemarine
1987 YJ Wrangler
It looks like swapping between speedos won't be that difficult, thanks guys! Ourlee I might have to take you up on that offer but first I would like to look into if I could swap an AX15/NP231 from a cherokee. I heard that the transfer case clocking was different, but other than that and the external clutch slave cylinder what else might I find that would set me back in doing this conversion? Again thanks a lot guys.
post #8 of 11 Old 03-28-2012, 05:54 AM
ourlee
i also have a 5 sp trans. from the same truck, also in perfect shape. pm if you want phone pics.
good luck. rick
2001 TJ 4.0 auto
ourlee is offline
post #9 of 11 Old 05-16-2012, 09:22 PM Thread Starter
gunnabemarine
1987 YJ Wrangler
Anyone ever seen something like this?
post #10 of 11 Old 05-16-2012, 09:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
All the time. Very common.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #11 of 11 Old 05-17-2012, 05:53 AM
crackedcornish
good luck. rick
if this trans is from the 4cyl yj that you mentioned earlier, it's not an AX-15 (unless it was swapped in) like the OP is looking for, it's an AX-5, that's not any stronger than what he already has
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
231 , ax15 , np231 , tranfer case , transmission
Busted 95yj-af YJ Wrangler Technical Forum 39 06-13-2011 08:17 PM
Busted!!! clintsharley TJ Wrangler Technical Forum 15 06-24-2008 07:58 PM
busted.. deecoop88 TJ Wrangler Technical Forum 42 04-07-2008 02:37 PM
HELP! Busted TJ!! loudog3114 TJ Wrangler Technical Forum 45 12-17-2005 12:06 PM
Busted? KYgreenYJ YJ Wrangler Technical Forum 7 06-07-2002 10:59 AM
