need help with brake master cylinder install - JeepForum.com
post #1 of 2 Old 08-26-2011, 04:05 PM Thread Starter
iwishihad1
hey everybody
well the master cylinder is on its way out in my YJ. I went by a shop today to get an inspection and although it stops ok, and brake pads are good, the pedal is soft and goes all the way to the floor. bleeding did not fix the problem so looks like its time for a new master cylinder. so options are bench bleed or some kind of bleeding with lines running from bottom of master cylinder back up into reservoir. anybody got any help or write ups to show how this is done
thanks
[CENTER]1995 fire red XJ, new 4.0, ARB safari snorkel, sye, front DS, aussie locked 8.8 5:13s 38 SXs, trussed/locked 44 front, hydro assist, DOM steering/COLOR]
YJ. 91 body, body off resto, crate chevy 350, 700r tranny, 2 inch springs, SOA, ford 9 rear, dana 44 front, both detroits, cage, 4:88s, and 36X14.50s. strictly street queen
iwishihad1 is offline
post #2 of 2 Old 08-26-2011, 09:00 PM
TSEJEEPERS
This is pretty basic video but it will tell you what to do.
When you buy a new master cylinder it will come with a bench bleeder kit and instructions. Just follow them it is not hard at all.
Make sure you bleed all the brakes after you install the new master, starting with the one farthest from the master. Passenger rear, drivers rear, passenger front and last drivers front.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
2.5 Brake Master Cylinder nohl75 YJ Wrangler Technical Forum 2 01-23-2011 06:16 PM
Brake Master cylinder lid Almost a jeep YJ Wrangler Technical Forum 1 12-11-2010 05:02 PM
Brake master cylinder NOAKES91yj YJ Wrangler Technical Forum 15 09-24-2010 11:27 AM
Master Cylinder and Brake Help fuzzyz11 JK Wrangler Technical Forum 5 06-11-2010 10:01 AM
95 Brake Master Cylinder CjinPA YJ Wrangler Technical Forum 3 07-26-2006 01:05 AM
