Need help on bouncing with new lift on 94 yj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Need help on bouncing with new lift on 94 yj
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 01-01-2014, 08:53 PM   #1
lifted94yj
Just got a new 4 inch lift on 33x12.5r15 on my 94 yj and have been having problems with major bouncing, would like help on how to stop this bouncing.
lifted94yj is offline   Reply With Quote Quick reply to this message
Unread 01-01-2014, 09:03 PM   #2
rykemc
Did you go with new shocks as well?
My Jeep build. :)
http://www.jeepforum.com/forum/f12/m...build-1502848/
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline   Reply With Quote Quick reply to this message
Unread 01-01-2014, 09:16 PM   #3
lifted94yj
Yes I have. 4 all new pro comp chocks
Unread 01-01-2014, 09:18 PM   #4
Sparrows
It's coming...
Sparrows's Avatar
What kind of lift?
Did you remove the track bars?
Nothing is over torqued?
Proper bushing sleeves?
What kind of shocks?
It's a SWB, leaf sprung Jeep. It ain't no caddy!
But there are ways to make it ride pretty well. We just need more info. And pics. Pictures help a lot.
And welcome to JF!
Cheers
WARBIRD 2
EXILED OFFROAD
June '13 YJOTM
Sparrows is offline   Reply With Quote Quick reply to this message
Unread 01-01-2014, 09:33 PM   #5
lifted94yj
Yes removed track bars, New bushings as well,everything is torqued correctly It's a trailmaster lift. Would it be the tire pressure and/or having the bolts on too tight?
Unread 01-01-2014, 09:39 PM   #6
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Mount tires at the same time as lift? Tire pressure too high? 26-28 psi should be all you need.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote Quick reply to this message
Unread 01-01-2014, 09:42 PM   #7
lifted94yj
I have the front at 40 and the back at 37. I think i should lower the psi probably
Unread 01-01-2014, 09:48 PM   #8
lifted94yj
New tires with the 4 inch lift. 33s
Unread 01-01-2014, 09:56 PM   #9
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Absolutely.
Unread 01-01-2014, 10:06 PM   #10
rykemc
Define "bouncy" for me please. Example. Do you mean it bounces going over a bump in the road like worn out shocks. Just keeps bouncing up and down? Or is it more like when you hit a bump it feels like it's hitting to hard and trying to "bounce" from that?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
Unread 01-01-2014, 10:14 PM   #11
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
If it still feels bouncy, after you lower the PSI, I'd check the shackle bolts, was the Jeep on it's own weight when they were tightened?
Unread 01-01-2014, 10:14 PM   #12
lifted94yj
What i meam by boucy is that with my stock lift i didnt feel a bounce at all on the normal roads i took, but with the lift i feel every single bump in the road. The other day i took a couple friends for a ride in the jeep and it didnt bounce at all compared to as if i were in it.
Unread 01-01-2014, 10:18 PM   #13
lifted94yj
Im not sure, my mechanic did it. But i have my own jack stand so i can loosen them tomorrow and then lower it, and tighten them accordingly.
Unread 01-01-2014, 10:18 PM   #14
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Too much tire pressure made my YJ feel every crack in the road, lowered it to 26 (on 33x12.5's) and it made a world of difference. I used MORE 5/8" shackles, which improved the ride and the flex.
Unread 01-01-2014, 10:18 PM   #15
rykemc
So it's more rougher ride than when it was stock?
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
