need help with bastard pack for SOA - JeepForum.com
post #1 of 7 Old 08-29-2011, 12:10 PM Thread Starter
'92 vegas YJ
so ill be starting my 8.8 SOA build soon and want some opinions. ive tried looking but nothing was specific to what i want to try
right now im running 4" pro comp springs with some beef 3/4" shackles.
i have some stock yj springs and some 1/2" booms that i plan on running.
what i am wondering is if i can make a bastard pack with my pro crap springs and stock to make the stock springs last a little longer. i dont want much height thats why im going with stock springs but i've heard sag REAL quick and dont last too long.
if i just used to main leaf from the pro comps would that help out? i know a lot of people are using s10 springs or XJ springs but those arent in the plans for right now, at least.
thanks in advance
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #2 of 7 Old 08-29-2011, 12:47 PM
TSEJEEPERS
That is what I would do.
The main leaf from the Pro Comp springs will have the open clamps.
It will help the leaves span out when flexing.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 7 Old 08-30-2011, 10:37 AM Thread Starter
'92 vegas YJ
Bump
Anyone else have an idea also?
post #4 of 7 Old 09-04-2011, 08:13 PM Thread Starter
'92 vegas YJ
no one else?
post #5 of 7 Old 09-05-2011, 06:41 AM
ssyj94
I'm running stock springs with an extra yj main in the rear for about a year and it's a little stiff. You could try running the procomp main with the rest of the yj pack, whats the worst that happens you take it back out. Are you planning on running a traction bar?
My build:
ssyj94 is offline
post #6 of 7 Old 09-05-2011, 06:47 AM
hesserdude07
your going to have to set the two springs next to each other on the floor and look at them to see what u can/wanna use from the two to make 1... sounds like it should work fine.
on my last set up i had a stock YJ main spring, next was Rancho 2" add a leaf, and then a 3" 3 leaf toyota add a leaf. I got also 4" over a stock setup and it rode great. Flex like mad cause all the leafs are thin.
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #7 of 7 Old 09-05-2011, 10:39 AM Thread Starter
'92 vegas YJ
yes i will be running a traction bar.
i think i will do as said, just lay them all out and see what works and what i like best...
Yj+yj bastard pack mbeck94 YJ Wrangler Technical Forum 11 05-31-2011 05:45 AM
Bastard Pack help please? bbl32 YJ Wrangler Technical Forum 1 01-18-2011 06:58 AM
The not really a bastard pack, bastard pack. yj98joe YJ Wrangler Technical Forum 0 01-02-2011 09:33 AM
Bastard Pack. WalrusPaul YJ Wrangler Technical Forum 0 08-10-2009 03:58 AM
bastard pack? will_982 YJ Wrangler Technical Forum 6 04-02-2008 07:19 AM
