need help badly - JeepForum.com
post #1 of 10 Old 10-22-2001, 09:27 PM Thread Starter
JYRUS
need help badly
have a 95 yj 6 cyl. when ran hard it makes a burning smell. i have had a complete tune up, o2 sen. changed, and a new cat. converter. what could it be?
JYRUS is offline
post #2 of 10 Old 10-22-2001, 09:54 PM
RodeoRob
RodeoRob's Avatar
probably the new cat buring in... its not at all uncommon to have a 'unique' smell after installing a new exhaust component (header, cat, muffler).
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 10 Old 10-23-2001, 09:48 AM
Kev
Master of the Obvious
Kev's Avatar
Do you have any oil leaks? I have had cars that the oil that has seeped out of the value covers and when they've been run hard, the oil starts to burn and smoke. Also, if the oil has been changed recently or oil added was it spilt on the exhaust or the engine?
Just a few possibilities.
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #4 of 10 Old 10-23-2001, 05:58 PM Thread Starter
JYRUS
no leaks anywhere. the car is as clean under and the paint. its not a cat. conv. smell. its a burning smell. its driving me crazy. i want to lift it lock it and gear it but if something is wrong with the engine i dont. it only has 65000 an it and was lady driven before i got it.
JYRUS is offline
post #5 of 10 Old 10-23-2001, 06:16 PM
RodeoRob
RodeoRob's Avatar
well oil could be leaking onto the exhaust manifold from a valve cover or somethign and buring up before it ever hit the ground. have you inspected your engine compartment for leaks?
is your exhaust normal? is there anything coming out of it (ie, black, white, etc. smoke)?
-Rob
Robert Gorrell
RodeoRob is offline
post #6 of 10 Old 10-24-2001, 10:19 AM Thread Starter
JYRUS
it doesnt smoke, leak or anything like that from anywhere, the only thing i get is black soot around the tail pipe.
JYRUS is offline
post #7 of 10 Old 10-24-2001, 09:12 PM
Big92Jeep
Take a look at the under side of your muffler. If there is a small leak from tranny seal or even grease from u-joints it can get thrown up on the under side of you muffler by the drive shaft.
I grease my u-joints about every 3 months. I get a nice burnt smell shortly after.
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #8 of 10 Old 10-24-2001, 09:53 PM
RodeoRob
RodeoRob's Avatar
So do you still have this smell? how long you had it? you notice it every time you drive? does your jeep having to be running for a while before you notice it?
If it was anything other than a leak, you would figure your exhaust would have burned it away by now?!
-Rob
Robert Gorrell
RodeoRob is offline
post #9 of 10 Old 10-26-2001, 10:20 AM
jeepinkid
If you have a stick it could be your clutch. if so go easy on it. and the problem will stop. you are most likely on the clutch pedal to long
jeepinkid is offline
post #10 of 10 Old 10-26-2001, 01:12 PM
Willis91YJ
Hey bud,
Check for oil in the air filter, Maybe the lady ran it low on oil and you have a shot ring?
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline
Need Help Badly Trytan74 YJ Wrangler Technical Forum 18 07-26-2009 08:45 PM
Need spark help BADLY Trytan74 YJ Wrangler Technical Forum 7 07-12-2009 10:52 AM
Shakes really badly davenjit TJ Wrangler Technical Forum 4 06-11-2009 09:50 AM
New guy here. Need some 4.2L help, badly. 1stuckdude YJ Wrangler Technical Forum 15 02-11-2008 07:42 PM
Need help badly!!!! 12345 YJ Wrangler Technical Forum 6 01-30-2007 02:22 PM
