-   -   need help badly (http://www.jeepforum.com/forum/f12/need-help-badly-7220/)
JYRUS 10-22-2001 08:27 PM
need help badly
have a 95 yj 6 cyl. when ran hard it makes a burning smell. i have had a complete tune up, o2 sen. changed, and a new cat. converter. what could it be?
RodeoRob 10-22-2001 08:54 PM
probably the new cat buring in... its not at all uncommon to have a 'unique' smell after installing a new exhaust component (header, cat, muffler).
-Rob
Kev 10-23-2001 08:48 AM
Do you have any oil leaks? I have had cars that the oil that has seeped out of the value covers and when they've been run hard, the oil starts to burn and smoke. Also, if the oil has been changed recently or oil added was it spilt on the exhaust or the engine?
Just a few possibilities.
JYRUS 10-23-2001 04:58 PM
no leaks anywhere. the car is as clean under and the paint. its not a cat. conv. smell. its a burning smell. its driving me crazy. i want to lift it lock it and gear it but if something is wrong with the engine i dont. it only has 65000 an it and was lady driven before i got it.
RodeoRob 10-23-2001 05:16 PM
well oil could be leaking onto the exhaust manifold from a valve cover or somethign and buring up before it ever hit the ground. have you inspected your engine compartment for leaks?
is your exhaust normal? is there anything coming out of it (ie, black, white, etc. smoke)?
-Rob
JYRUS 10-24-2001 09:19 AM
it doesnt smoke, leak or anything like that from anywhere, the only thing i get is black soot around the tail pipe.
Big92Jeep 10-24-2001 08:12 PM
Take a look at the under side of your muffler. If there is a small leak from tranny seal or even grease from u-joints it can get thrown up on the under side of you muffler by the drive shaft.
I grease my u-joints about every 3 months. I get a nice burnt smell shortly after. ;)
RodeoRob 10-24-2001 08:53 PM
So do you still have this smell? how long you had it? you notice it every time you drive? does your jeep having to be running for a while before you notice it?
If it was anything other than a leak, you would figure your exhaust would have burned it away by now?!
-Rob
jeepinkid 10-26-2001 09:20 AM
If you have a stick it could be your clutch. if so go easy on it. and the problem will stop. you are most likely on the clutch pedal to long
Willis91YJ 10-26-2001 12:12 PM
Hey bud,
Check for oil in the air filter, Maybe the lady ran it low on oil and you have a shot ring?
Willis
The time now is 09:26 PM.
