Need help with AX-5 - JeepForum.com
post #1 of 3 Old 05-04-2011, 02:04 PM Thread Starter
ColeYJ
Need help with AX-5
Goin to go look at a transmission for my yj 2.5 this weekend!
Is there any way to tell if it a good transmission when it's sit-n on the floor??
Any tip's or hints would be great! Just hate to do all that work tradeing them out and it's worse than my old one!...........Thanks Cole
ColeYJ is offline
post #2 of 3 Old 05-04-2011, 03:50 PM
AaronJ
Most of the problems that are associated with the ax5 will only show up once you try to drive it (worn synchronizers, popping out of gear, etc).
You can spin the input shaft by hand and make sure the output shaft turns in every gear (1-5 + reverse) but that won't mean the transmission is good.
AaronJ is offline
post #3 of 3 Old 05-04-2011, 07:56 PM
moonshinefuel
You will be relying 100% on what the seller tells you. That's it. Except of course the things Aaronj mentioned. Good luck.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
