Need help ASAP!!! Unknown problem?? - Page 2 - JeepForum.com
post #16 of 20 Old 05-16-2010, 02:49 PM Thread Starter
aolitesnsirens
Originally Posted by MLJeeper View Post
Im not sure, but yeah i think so.
What about the starter relay on the passenger side firewall?? I just read this on another website...
This Relay Will Cause Your Engine To Crank But Never To Start When It Goes Bad. This Relay Is Located On The Inside Of The Passenger Fender Well. It Only Takes Minutes To Replace With A Few Tools For Anyone & Does Not Require A Mechanic. If You Can Not Start Your Engine & It Just Cranks-This May Be The Problem.
http://www.teamgrandwagoneer.com/par...iled/3724.html
aolitesnsirens is offline
post #17 of 20 Old 05-16-2010, 03:01 PM
MLJeeper
MLJeeper's Avatar
Does your engine crank but immediately shuts off or does it roll over and never fire at all?
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #18 of 20 Old 05-16-2010, 03:12 PM Thread Starter
aolitesnsirens
The engine cranks, does not fire. There is no fuel getting to the carb. I D/C'd the fuel pump from the jeep yesterday and connected it to a 12v power source and got the pump to work, so I know that the pump is good. However, I don't know why there is no power to the pump when it is connected to the vehicle. I haven't tested that starter relay yet, but that is the next thing I will do. I found that yesterday when I was looking for a fusable link that possibly could have gone bad and didn't know what that was until today when I googled the CPS and found electrical parts on another web site.
post #19 of 20 Old 05-16-2010, 03:50 PM
Mark05059
ground at the e-brake mount? Change the fuel pump relay with the asd relay and see if you have power at the fuel pump afterward.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #20 of 20 Old 05-16-2010, 03:51 PM
89CoolJeep
Junior Member
On the drivers side firewall is a white box (outside firewall) that going bad causes a lot of things not to work, including running. It is 50 for a new one, try changing that. Also check your fusable links. Fusable link sounds a little more likely. I had fjusable link fall apart at 65 and the truck dies instantly. They are on the passenger side ,external a box with a lot of wires going to it, if the fusable link is bad it would be the same problems your having. If this is what is wrong, make sure you use special fusable link wire and put a fuse holder so you can change fuse if it blows. If you don't use correct wire the fuses will keeping blowing
89CoolJeep is offline
Help, unknown TJ problem.... (dead battery, now low idle) smcurry83 TJ Wrangler Technical Forum 14 05-10-2008 07:35 PM
Brake Problem!!! ASAP BJ5781 TJ Wrangler Technical Forum 3 04-27-2008 10:10 PM
98TJ Unknown problem... rangersmith TJ Wrangler Technical Forum 6 10-11-2006 06:54 PM
Unknown problem with 2001 TJ rcunning TJ Wrangler Technical Forum 12 02-20-2006 03:46 PM
