Need help asap... - JeepForum.com
post #1 of 11 Old 12-03-2013, 10:05 AM Thread Starter
33chief
1987 YJ Wrangler
Need help asap...
I was changing my thermostat and I sheared off the bottom bolt what can I do
33chief is offline
post #2 of 11 Old 12-03-2013, 10:10 AM
superj
drill it out
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 11 Old 12-03-2013, 11:00 AM
EABiker
Get and easy-out. First, you drill a hole in the center of the broken bolt and then, insert the Easy-out. It has coarse, reverse threads, so when you screw it in, it unscrews the broken bolt.
EABiker is offline
post #4 of 11 Old 12-03-2013, 11:57 AM
Latefreight727
Be really careful with the easy out. They are hardened and if you break the easy out you will have a big headache on your hands. I would drill and tap
Latefreight727 is offline
post #5 of 11 Old 12-03-2013, 12:39 PM
jeepguy85
1987 YJ Wrangler
If any of the bolt is sticking out, you could use an extractor. It is the same principle as the easy out, but a heck of a lot easier to use. It is like a socket that goes over the outside of the bolt/nut and you can use it with a ratchet or air ratchet.
http://www.irwin.com/tools/browse/sc...olt-extractors
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #6 of 11 Old 12-03-2013, 12:45 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
can you post a picture of the broken bolt?
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is online now
post #7 of 11 Old 12-03-2013, 01:33 PM
imstillatwork
Picture would be great. Sometimes this is not a big deal. remove the rest of the bolts, remove the part, and you will have 1/4" of bolt sticking out to vice grip and remove.
Pics would help though!
imstillatwork is offline
post #8 of 11 Old 12-03-2013, 04:23 PM Thread Starter
33chief
1987 YJ Wrangler
I was able to get a purchase point on the little bit of the bolt that was sticking out. I thankfully was able to get a pair of needle nose vise grips on it and twist the remaining piece out!
Thanks for the help
33chief is offline
post #9 of 11 Old 12-03-2013, 05:36 PM
imstillatwork
Perfect!
post #10 of 11 Old 12-03-2013, 05:44 PM
jeepguy85
1987 YJ Wrangler
Good deal!
post #11 of 11 Old 12-03-2013, 11:55 PM
jred
Man, I never get that lucky :P
jred is offline
