Need help with aftermarket guages - JeepForum.com
post #1 of 13 Old 12-10-2006, 09:20 AM Thread Starter
loborojo338
I am thinking about swapping my factory 87 YJ guages to some Autometer ones. My question is which fuel guage should I buy that will work with my stock sending unit? Thanks in advance.
91 YJ
2.5 low output,32's and 5.5 inches of lift
8,000 lb winch,Tube Fenders and custom bumpers soon to come
www.emeraldcoastjeepers.com
loborojo338 is offline
post #2 of 13 Old 12-10-2006, 10:37 AM
jeep63
jeep63's Avatar
I just completed this in my 89YJ. I replaced the entire gauge package with Autometer Phantom gauges, and a new gauge pod from Quadratec. Below are the Autometer part numbers.
Water Temp Gauge: 2 1/16" WATER TEMPERATURE GAUGE 5737
Fuel Guage: 2 1/16" GM Electric Fuel Level Gauge #5714
Electric Clock: 2 1/16" ELECTRIC CLOCK GAUGE 5785
Oil Pressure Gauge: 2 1/16" Oil Pressure Gauge #5727.
Volt Meter: 2 1/16 PHANTOM VOLTMETER VOLT GAUGE 5791
The end result is very nice and all the gauges are of high quality.
jeep63 is offline
post #3 of 13 Old 12-10-2006, 10:59 AM
Nagao
How straight-forward was that install for you? Did you only have to plug in and drive off? Also, share some pictures if you have any.
Nagao is offline
post #4 of 13 Old 12-10-2006, 11:26 AM
jeep63
jeep63's Avatar
It was very staight-forward since I have the FSM and I could map the correct wires. I created my own harness and plugs, so I can remove the whole gauge pod in a manner similar to stock. Unfortunately, I did not take any pictures during the process. Here are some post install pics.
jeep63 is offline
post #5 of 13 Old 12-10-2006, 03:13 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
fyi, summitracing has the cheapest prices on the phantom gauges that i've been able to find.... even comparing to eBay summit is cheaper after factoring in shipping... and they're in stock....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #6 of 13 Old 12-10-2006, 05:55 PM
90yjkrawler
Has anyone ever cut up the dash where the speedo and tach are and installed after market gauges? If you have, do you have pictures?
Until They All Come Home!
90yjkrawler is offline
post #7 of 13 Old 12-10-2006, 06:55 PM
Nagao
How do those gauges illuminate? Also, I'm sorry but please tell me FSM is full service manual.
Nagao is offline
post #8 of 13 Old 12-10-2006, 07:03 PM
Burnerman
Burnerman's Avatar
FSM = Factory Service Manual
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #9 of 13 Old 12-10-2006, 07:16 PM
Nagao
I was close
Nagao is offline
post #10 of 13 Old 12-10-2006, 07:23 PM
jeep63
jeep63's Avatar
Better to ask and find out the answer then to assume and be wrong.
Each gauge comes with its own light and two different light covers: one green and one red. I put the red covers on and I am pleased with the outcome. I had two bulbs burned out in the tach and speedo, so I put red bulbs in them too. It all turned out pretty nice.
jeep63 is offline
post #11 of 13 Old 12-10-2006, 07:54 PM
Marauderk
I replaced all my gauges with autometer lunar's and love it easy to do and looks great.
89 YJ Islander Yellow, 258 Clifford intake holly carb MSD 6
Smittybilt flat fenders, Dick Cepek 3.5 in lift, Warn 8000I
2007 Rescue Green 2d Rubicon 6 speed soft top
Rubicon express 3.5 superflex system,35 in interco truxs mt's, skidrow skid plates, Killby muffler plate
Marauderk is offline
post #12 of 13 Old 12-10-2006, 07:59 PM Thread Starter
loborojo338
Thanks for the info!!
91 YJ
post #13 of 13 Old 12-10-2006, 09:38 PM
350Jeep
I also swapped all my gauges, including speedo and tach with Autometer Ultra-Lites. Built my own custom polished aluminum dash that follows the stock contour. Got rid of the 4WD indicator and run speedo and tach in the stock locations and fuel, oil pressure, water temp. and battery volt. across the middle. Also on there are indicator lights for turn signals, parking brakes, and highbeams. PM me your email and ill send you some pics if you want.
'92 Wrangler, 350ci Chevy w/ Holley Truck Avenger carb, B-W WC T4, NP231 w/ JB conversions SYE, Ford 8.8 rearend w/ ARB, Dana 44 front w/ ARB, 4.10's, Rubicon Express XD 4.5" lift, 35" MT/R's on 15"x8" American Racing wheels, 6" Bushwacker cut-out TJ-style fender flares, custom polished aluminum dash w/ full set of Autometer Ultra-Lite gauges, Warn HS9500i winch, Big Daddy Step Rock Rails, custom, self-made rear bumper
350Jeep is offline
Tj aftermarket guages !HELP! Musketman TJ Wrangler Technical Forum 7 01-12-2010 04:23 PM
Aftermarket Guages rubbertoe TJ Wrangler Technical Forum 9 04-19-2009 04:46 PM
Bouncing guages and "ticking" behind guages (short?) johnso26 TJ Wrangler Technical Forum 7 11-12-2008 10:03 AM
those with aftermarket guages Scott00TJ TJ Wrangler Technical Forum 1 02-10-2007 04:03 PM
Guages... FlyboyTJ TJ Wrangler Technical Forum 5 12-29-2003 08:39 AM
