Need Help: 93 YJ - Page 2 - JeepForum.com
post #16 of 27 Old 02-05-2013, 07:44 AM Thread Starter
JackNCoke
What would be a good way to clean the springs, rockers, and rods without taking the head off? Not much room to work with here
JackNCoke is offline
post #17 of 27 Old 02-05-2013, 08:37 AM Thread Starter
JackNCoke
Okay just started cleaning the valve cover and baffle. The hose that is coming off of the rear of the valve cover seems to be clogged when I blow in it. I told that this is the CCV port? Hopefully after I clean the port and the baffle my problem will be fixed. I
post #18 of 27 Old 02-05-2013, 08:39 AM Thread Starter
JackNCoke
This is what I'm thinking the problem is
post #19 of 27 Old 02-05-2013, 08:52 AM
ROTTEN
Yes
I Googled a pic -jeep 4.0 ccv
They show that as the ccv
I would imagine if it was blocked it wants to push out another valve I.e. your situation.
Surprising though because usually the valve cover bolts turnout and vent it for you. . And leak...
I'm new
ROTTEN is offline
post #20 of 27 Old 02-05-2013, 09:08 AM
Que89YJ
Use carb cleaner on the head. Plug the oil ports so the gunk you clean off doesnt go down inside. When you get does run one of the heavy detergents like seafoam or kerocene, etc for a couple minutes and change the oil out. That is bad but common. The 2.5l/4.0 can both take a beating. Man that is bad!
Que89YJ is offline
post #21 of 27 Old 02-05-2013, 09:24 AM
pasinbuy
Originally Posted by Que89YJ View Post
I personally dont think you need to pull the head. With no ventilation the top end will crud up just the way yours did. Clean it and you should be fine. If you want to run the wet/dry compression test. If the test is good then leave it together and clean it.
I agree. Why take on work not needed.
pasinbuy is offline
post #22 of 27 Old 02-05-2013, 09:35 AM
pasinbuy
After your clean up. Run a can of Seafoam through your oil and then change the oil. Put a few miles on her to clean it well. Not just idle for a few minutes and drain.
pasinbuy is offline
post #23 of 27 Old 02-05-2013, 12:21 PM
Que89YJ
I need to correct my post not pcv like they said ccv.
Que89YJ is offline
post #24 of 27 Old 02-09-2013, 02:36 PM Thread Starter
JackNCoke
Thanks to all replies! The jeep is back up and running. Here's what I did.
1. Took valve cover off.
2. Cleaned off top of valve train best I could with carb cleaner.
3. Cleaned valve cover and baffles with carb cleaner.
4. Drained oil and ran kerosene thorough top of the valve train and let it run out the bottom of the oil pan.
5. Put it all back together.
6. Put 4 1/2 quarts of cheap oil and filter on, the. Put to cans of seafoam motor treatment in.
7. Started jeep and put about 40-50 miles on it.
8. Drained oil until none coming out. Left the bleeder but off the oil pan and poured cheap oil into the valve cover I until clean oil was coming out the bottom.
9. New filter, 5 quarts moible 1 and 1 quart Lucas oil stabilizer.
10. Jeep runs great no oil blow back!
post #25 of 27 Old 02-09-2013, 02:46 PM
ROTTEN
Excellent!
I'm new
ROTTEN is offline
post #26 of 27 Old 02-09-2013, 02:51 PM
140mower
Sounds like you've got it licked there, good deal. By looking at the picture it would appear you're getting out there and enjoying your Jeep. If I can offer a little advice based on the photo, when you get back from deep water crossings etc be sure to grease everything to push out the water trapped in the u-joints etc., plus check your trans, transfer case, and diff oils for level and water contamination. Oil seals are primarily designed to keep oil in, but not so much for keeping fluids out, it's time well spent and cheap insurance.
Don
If it wasn't done the hard way, I didn't do it.
140mower is offline
post #27 of 27 Old 02-09-2013, 03:31 PM
Que89YJ
Thanks for posting it back. That was real bad.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
