Need Help!! 1993 YJ will not fire up! - JeepForum.com
post #1 of 25 Old 03-27-2011, 04:55 PM Thread Starter
ZerOc00l
Hey there
I have been battling with my jeep now for 3 days
Doing as much research as I could to nail down the problem but nothing is going my way
Recently I changed out rear bearings and axel seals due to a leak in the rear driver tire
Also replaced rear brake system because it was leaking
Did a hardware kit, new lines, and brake pads for the drums
I also replaced the fuel filter, double checked to make sure it was put on properly, in facing gas tank, out facing the front
Did a 1200km road trip no problems at all
Seemed like I had everything fixed when this damn jeep quit starting on me
Here are symptoms and what I have done thus far
2 days before the jeep finally quit starting
I started noticing it was taking longer to start each day, I mean really cranking it for a good 10-12 seconds and she fired. But was starting up finally with some difficulty. Engine would almost want to stall but it did go. After that first start of the day, no problems starting afterwards
When it finally quit, it would crank, starter going, battery had good charge
Just wouldn't fire up. I started checking the spark plug wires. No spark or hardly any. Next I checked the wire coming from ignition coil to distributor for resistance.
I had no reading at all sometimes, then it would fire a reading of .3-.5 ohms and I would get a bit of a jolt. Haynes book says at least .97 OHMS.
So yesterday I replaced the ignition coil. I'm getting a good reading now at the spark plug wires but it still won't fire
I should note that starter is AC Delco. Distributor cap and rotor, spark plugs, spark plug wires all replaced about 9-12 months ago.
I took out my old wires. Hooked them back up. Still won't fire up.
The other thing I have noticed is now, when I fire the jeep up. It almost wants to fire up but won't. You can hear the engine want to fire up but it won't go.
I can smell gas by the engine when I'm pumping the peddle to get it to go.
Checked fuse at the PDC, and under dash. No blown fuses
Not sure how to check relays.
I checked for codes yesterday as well
Got a code 12, code 33, code 41, code 51
I reset the computer today by pulling off positive cable for 20 minutes. Only have code 12 and 33 now
Jeep still won't fire up.
I have been reading my Haynes book like crazy and I'm headed back out to do more testing
Only thing I can think of is ignition module, PCM, and timing chain
All wires I have checked look in good shape and hooked up
So, now I'm turning to the forum for help as I'm to the point I have to go to a mechanic shop and let them fight with it
Anyone have some ideas or suggestions for what else I can try to narrow down the problem based on what I have been telling you??
Any help is appreciated as im ready to start pulling my hair out from the bs I've gone through.
Thanks everyone
ZerOc00l is offline
post #2 of 25 Old 03-27-2011, 05:29 PM
kelti819
so you have spark and fuel and air.....thats what you need to start a motor...so now you need to verify that you did not bump something loose while working on it. also check the crank positon and cam postion sensors. one is on the trans, the other in the distributor. chances are that since you can pull codes it is not the computer, but a sensor. im sure Que will see this and chime in as to anything i may have missed
kelti819 is offline
post #3 of 25 Old 03-27-2011, 05:35 PM
Xenephobe375
Sorry if missed something cuz I just skimmed over it all, but did you test the pressure at the fuel rail? Not sure of the exact psi but should be at least 35 psi. Mine was having problems starting as well, then it came to the point where it would start, if at all, and just stumble and stall. My guess would be the fuel pump went bad on yours as did on mine. Seems I caught mine before it totally went as it was still starting sometimes.
A no start can definitely be caused by a bad fuel pump.
Oh and when mine was going, I only had 14 psi.
Xenephobe375 is offline
post #4 of 25 Old 03-27-2011, 05:41 PM Thread Starter
ZerOc00l
I just checked at the back of the jeep to see if I can hear the fuel pump engaging and I can hear it
I'm headed to buy a pressure check tool for my vehicle right now. See what that turns up
I will check my sensors as well and get back to you guys
Can I check the timing chain somehow??
I was told to pull of distributor cap and turn it. See if the rotor turns?? That make sense at all??
ZerOc00l is offline
post #5 of 25 Old 03-27-2011, 05:43 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
You have a good spark and air then I think fuel pressure (or delivery) is the problem, also. That the problem has been developing over several days makes me think that. Could be the fuel pressure regulator.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #6 of 25 Old 03-27-2011, 05:47 PM
fishgutz
2010 MK Patriot
Last time my YJ wouldn't start it was the coil.
fishgutz is offline
post #7 of 25 Old 03-27-2011, 06:19 PM Thread Starter
ZerOc00l
Well
Store didn't have any fuel pressure testers in stock till tomorrow morning
So, im going to keep testing electrical here
I'm guessing to check fuel pressure regulator, fuel tank has to be dropped??
Nevermind that question, just checked my Haynes/Chilton book to see it's in the throttle body assembly
I'm guessing though no ordinary tools can test that?
ZerOc00l is offline
post #8 of 25 Old 03-27-2011, 06:33 PM
alilredjeep
alilredjeep's Avatar
Have you searched for "ecu capacitor"?
Theres a big write up somewhere on JF and IIRC the symptoms are similiar to yours.
Eddie
RED JEEP CLUB MEMBER #92
'92 WRANGLER, 2.5 Litre, 5 Speed, Rag Top, Superwinch LP8500, Cepek 130W Driving Lights, 31x10.50/AT with no lift, Of course! It rubs!
alilredjeep is offline
post #9 of 25 Old 03-27-2011, 07:05 PM
Que89YJ
You can spray some starting fluid into the throttlebody to see if it cranks. If it does then its a fuel issue. You check fuel pressure at the fuel rail in the front by the throttlebody(Youtube has some general videos on how). If you see the CEL then the Capacitor should be good.
x2 with a probable fuel issue.
Que89YJ is offline
post #10 of 25 Old 03-27-2011, 07:50 PM Thread Starter
ZerOc00l
Well it was getting dark around here and saw a bunch of sparks shooting out by the starter when me and buddy were cranking it over
I'm pretty sure that isn't normal
Anyone have an opinion on that??
ZerOc00l is offline
post #11 of 25 Old 03-27-2011, 07:59 PM
RustedWrangler
Your codes give you a starting ground to check the problem out.
Look them up here if you don't know how to do it.
Cherokee Engine Diagnostic codes
88 Start of test (This only appears on DRBII, it's not blinked out)
11 No ignition reference signal detected during cranking (bad hall effect) OR timing belt skipped one or more teeth; or intermittent loss of either camshaft or crankshaft position sensor
12 Memory Standby power lost (Batt or computer recently disconnected)
13 No change in MAP from start to run
14 MAP sensor circuit open or shorted; voltage too low
15 No speed/distance sensor signal
16 Loss of battery voltage detected with engine running
17 Engine stays cold too long (bad thermostat)
21 Oxygen sensor signal out of range, possibly shorted
22 Coolant sensor signal out of range (or disconnected to set timing)
23 Intake air temperature signal out of range
24 Throttle position circuit out of range
25 Automatic Idle Speed (AIS) motor driver circuit shorted or target idle not reached, vacuum leak found
26 Peak injector circuit voltage has not been reached
27 Logic module fuel circuit internal problem or TBI injector does not respond properly to control signal
31 Evaporator Purge solenoid circuit open or shorted or Evaporator solenoid circuit
32 EGR system failure or Power loss lamp open or shorted
33 Air conditioning clutch relay circuit open or shorted ( Also will show up for rigs without AC)
34 Speed control vacuum or vent solenoid circuits open or shorted
35 Cooling fan relay circuit open or shorted
36 Wastegate control circuit open or shorted
37 Shift indicator light failure, 5-speed (blown bulb) OR Park/neutral switch failure OR Torque converter unlock circuit open or shorted, A-413 4-speed auto
41 Alternator field control circuit open or shorted
42 Automatic shutdown relay circuit open or shorted
42 Fuel pump relay control circuit
42 Fuel level unit - no change over miles OR Z1 voltage missing when auto shut-down circuit energized
43 Peak primary coil current not achieved with max dwell time OR Cylinder misfire
43 Problem in power module to logic module interface
44 No FJ2 voltage present at logic board OR Logic module self-diagnostics indicate problem OR Battery temperature out of range
45 Turbo boost limit exceeded (engine was shut down by logic module)
46 Battery voltage too high during charging or charging system voltage too low
47 Battery voltage too low and alternator output too low
51 Oxygen sensor stuck at lean position OR Internal logic module fault ('84 turbo only)
52 Oxygen sensor stuck at rich position OR Internal logic module fault ('84 turbo only)
53 Logic module internal problem
54 No sync pickup signal during engine rotation (turbo only) OR Internal logic module fault ('84 turbo only)
55 55 End of codes
61 "Baro" sensor open or shorted
62 EMR mileage cannot be stored in EEPROM
62 PCM failure SRI mile not stored
63 Controller cannot write to EEPROM
64 Catalytic converter efficiency failure
65 Power steering switch failure
www.RCPFA.com
RustedWrangler is offline
post #12 of 25 Old 03-27-2011, 08:25 PM
Que89YJ
Sparks from the starter.....not good. You need to get underneath it and see whats up. Probably loose wires arcing.
Que89YJ is offline
post #13 of 25 Old 03-27-2011, 08:46 PM
nembudonna
Have you done a compression test? Air,fuel and spark aren't enough.
nembudonna is offline
post #14 of 25 Old 03-27-2011, 08:56 PM
bigbelman2009
an easy way to check the fuel pump is to turn the key on for a few seconds then off for a few seconds, do that 4 or 5 times and then try to start it. by cycling the key on and off your building the fuel pressure up. if it fires up then dies your fuel pump isnt putting out the psi your motor needs
bigbelman2009 is offline
post #15 of 25 Old 03-27-2011, 08:58 PM
ReMike
I would also check the Crank Position Sensor.. i fought with my jeep about a week ago and notice my starter was starting to smoke.. was under warranty so i went and got another one..also picked up a CPS, put them on and it fired right up.
ReMike is offline
1993 4.0 fire order problem 88YJoe YJ Wrangler Technical Forum 4 11-02-2010 09:08 AM
"After the fire, the fire still burns" 88 YJ 258 T.Maxwell YJ Wrangler Technical Forum 0 09-22-2009 09:02 PM
Desperation, 1993 Jeep will not fire..replaced brain, crank sensor, ignition coil... amsgwp YJ Wrangler Technical Forum 3 03-24-2009 12:15 PM
My 1993 4.0 6 cyl won't run Vickie YJ Wrangler Technical Forum 2 03-13-2008 06:53 PM
fire fire! pics *Jeremy* YJ Wrangler Technical Forum 13 09-25-2003 09:35 PM
