Need help - JeepForum.com
post #1 of 3 Old 10-05-2013, 05:25 AM Thread Starter
pvfd_1110
Need help
I have a 92 yj with a 4.0 and an ax15. It was recently submerged in water up to the hood. I drained all of the water our of everything and cleaned everything with diesel fuel/transmission fluid mix. It cranks fine when you crank it for the first time. If you park it and crank it up a few minutes later you have to put the gas to the floor for it to crank and you have to hold it on the floor after it cranks for about a minute until it starts running right. It sounds like it is only hitting on a couple cylinders until all of a sudden it springs to life and tachs out. I have changed plugs wires rotor button distributor cap and fuel filter. The computer was throwing codes for tps map sensor oxygen sensor and the coolant temp sensor. I changed all of them and now it is still throwing the codes for the coolant temp sensor and map sensor. I have reached my level of ignorance with it.
pvfd_1110 is offline
post #2 of 3 Old 10-05-2013, 08:04 AM
WDNewman
Check out the crankshaft position sensor. Water could have messed it up, and I am not positive that it would show up on the codes. Until I replaced mine the engine was all but dead below 1,800 RPM but would come to life above that level. It also caused the starting problems you mention.
WDNewman is offline
post #3 of 3 Old 10-06-2013, 12:22 PM Thread Starter
pvfd_1110
Thanks man I forgot about the crank sensor. I will check it out.
