Need Help!!! - JeepForum.com
post #1 of 9 Old 04-25-2013, 03:26 PM Thread Starter
Birddogg
Need Help!!!
Ok a little back story I've had my yj for 2.5 yrs and have not had any issues with it outside of a blown u joint and cracked t-case. Then on Tuesday 4/23 my yj dies on me at a gas station I had just drove it approx. 10 Miles from my Grandparents house to my house then 2 Miles to the gas station to get a pop. I shut it off and went inside with no issues I come back out and it starts hard and wont idle and dies when I give it gas.
I tow it home Replace the TPS and Crankshaft Position Sensor now it will idle all day but if I give it any gas it dies. I put a new fuel filter on thinking it might be pluged and it made no difference. Do I need a new fuel pump? I can hear the pump kick on for 3-5 sec. when I turn the Key on. Or is my problem some where else?
My jeep is a 1992 4.0 manual trans.
Birddogg is offline
post #2 of 9 Old 04-25-2013, 03:30 PM
superj
what is your fuel pressure?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 9 Old 04-25-2013, 06:45 PM Thread Starter
Birddogg
So I went to Autozone and Rented a tester and my fuel pressure during the prime cycle was 0, and the pressure at idle was 10 Psi.
Birddogg is offline
post #4 of 9 Old 04-26-2013, 10:32 AM
Que89YJ
I would get a different guage, it sounds like it is bad. 10 psi isn't enough to keep it running. That being said, the fact you didn't get the same number on both is indicating a pump problem. Prime and running you should have 31psi. I think you are looking at dropping the tank and doing a fuel pump.
Que89YJ is online now
post #5 of 9 Old 04-26-2013, 11:39 AM
Kuntryboy816
Kuntryboy816's Avatar
Originally Posted by Birddogg View Post
... then 2 Miles to the gas station to get a pop.
I haven't heard it called 'pop' since my childhood in VA. >memories<
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is online now
post #6 of 9 Old 04-26-2013, 11:41 AM Thread Starter
Birddogg
Ok thanks, any idea why it would go all at once like that. I thought that when a fuel pump goes it would act up for a little bit first.
Birddogg is offline
post #7 of 9 Old 04-26-2013, 11:52 AM
pasinbuy
In Michigan it has always been called Pop.
pasinbuy is offline
post #8 of 9 Old 04-26-2013, 12:02 PM
Que89YJ
It is Pop all day long....
I would second check the reading but the test tell you what you need to know. If that pressure is low then there is no doubt your issue is fuel pump or the supply line. You can check the supply line for any kinks in it but unless you were out wheeling I dint think you leave any doubt. Check the guage on another any other car to see if the fuel presssure is good. If it is then I would drop the tank and also do the tank access mod. Post back with what you find out. Siva went through 3 guages trying to get one that works.
post #9 of 9 Old 04-26-2013, 12:15 PM Thread Starter
Birddogg
Ok thanks
Birddogg is offline
