Need a hand with some measurements - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Need a hand with some measurements
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 02-15-2014, 09:54 PM   #1
FlexinYJ
I'm in the process of redoing the motor mounts in my YJ. What I need help with from y'all out there that have 4.0 and 5 speed transmissions is the distance from the front of the frame rail to the front of the motor mount where it welds to the frame if that makes sense.....reason being is I have an aw4 from a cherokee in my jeep and since they are so long the motor was moved forward to make up for the extra length in the trans and also so my rear driveshaft wouldn't be the length of a bic pen. I'm swapping to an ax15. I have new frame mounts I just don't know where to weld them. Thanks in advance for the help! Also pics would be great if anyone has them!
"If parts aint flyin, YOU AINT TRYIN!!" Morris Mountain ORV Park.
FlexinYJ is offline   Reply With Quote
Unread 02-16-2014, 08:37 AM   #2
jbolty
jbolty's Avatar
This might help until someone can grab a tape measure
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
