Need a full carrier for my front HP30 - JeepForum.com
post #1 of 15 Old 04-08-2014, 03:52 PM Thread Starter
NotThePainter
I have Auburn ECTED lockers in my front HP30 and my rear Ford 8.8. Both are out of the D-Rex program and both have failed. Auburn wants an arm and a leg for replacements, more than even Quadratec!
I'm not putting the back in. I was thinking just going with lunchboxes front and rear but I guess I can't, I need full carriers.
What are my options here? I was thinking of a Detroit in the rear and I guess I could put one up front also. But now we're really starting to talk some serious coin. I suspect we'll sell the YJ after 2 more seasons.
I guess I could run Open up front but I really don't like that idea.
NotThePainter is offline
post #2 of 15 Old 04-08-2014, 07:08 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Spool rear and open carrier front with lunchbox.
Luck Favours The Prepared
Anticanman is offline
post #3 of 15 Old 04-09-2014, 04:48 AM Thread Starter
NotThePainter
How do I get a lunchbox into the front with the ECTED already in place? The ECTED is already a full carrier.
post #4 of 15 Old 04-09-2014, 05:54 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Buy a new/used carrier. Depending on your grears you could get a carrier from the junkyard out of a 6cyl (3.07 gears) or a 4cyl (4.11 gears). Carrier break for gears ratios are easy to find using the search and are probably listed in the FAQ.
-John-
johnboy68 is offline
post #5 of 15 Old 04-09-2014, 06:29 AM Thread Starter
NotThePainter
Originally Posted by johnboy68 View Post
buy a new/used carrier. Depending on your grears you could get a carrier from the junkyard out of a 6cyl (3.07 gears) or a 4cyl (4.11 gears). Carrier break for gears ratios are easy to find using the search and are probably listed in the faq.
4.88 :- (
post #6 of 15 Old 04-09-2014, 07:39 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Replace the carrier. You were gonna do that anyway.
post #7 of 15 Old 04-09-2014, 07:43 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Unless my research is no good, 4.88 gears will work in a stock Dana 30 that came with 4.11 gears. This would be an axle out of a 4cyl.
So, find you a Dana 30 out of a 4cyl wrangler. I got a compelte axle for $150. You may be able to find a used carrier for less.
-John-
post #8 of 15 Old 04-09-2014, 08:10 AM
tom_sprecher
I just bought one of these for putting 4.11 gears in mine.
http://eastcoastgearsupply.com/i-129...r-3-73-up.html
Tom
tom_sprecher is offline
post #9 of 15 Old 04-09-2014, 03:30 PM Thread Starter
NotThePainter
Now that's more like it. That a lunchbox and I'm good?
post #10 of 15 Old 04-09-2014, 03:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yep.
post #11 of 15 Old 04-09-2014, 03:38 PM Thread Starter
NotThePainter
Yep.
But shouldn't a part I need be more expensive?
post #12 of 15 Old 04-09-2014, 04:27 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
No. But...
You will need to find someone who can set your gears back up.
So, you will leave your pinion where it is. You'll take the ring off your current carrier and put it on the new carrier. And the Aussie in the place of your spider gears.
But, if you just bolt it all up it will fail. Find someone who can set it all back up for you.
-John-
post #13 of 15 Old 04-09-2014, 04:29 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
I forgot to mention, not sure if that new carrier from ECGS comes with bearings. So you may need to buy a master install kit too.
-John-
post #14 of 15 Old 04-09-2014, 04:44 PM Thread Starter
NotThePainter
No. But...
Funny, I used to wrench on my cars and haven't in a long time. Was thinking of doing this one. But no, I'll give it to my guy to do, he knows Jeeps.
Thanks!
post #15 of 15 Old 04-09-2014, 05:33 PM
tom_sprecher
It does not, so bearings, shims and a gasket will be needed.
Tom
