Need Frame Fixed!!!! - JeepForum.com
post #1 of 4 Old 03-08-2008, 06:30 AM Thread Starter
05NHWrangler
I need some help or suggestions to help my situation...I just had a Jeep YJ given to me. And the Jeep is in excellent condition inside and out. But...the crossmember that holds the transfer case and transmission is rusted out. I know it bolts to the frame and it costs about 350.00 for the new plate. The problem is the nuts that are welded to the frame are rusted out as well. Is there anyone that has gone through the same issue? and how did you fix it? and is it worth the hassle? Thanks
05NHWrangler is offline
post #2 of 4 Old 03-08-2008, 06:42 AM
nasnop
Not an easy fix, but not impossible. The best way is to get a look at it.
BTW, if you're in NH, you may want to check out www.newjo.org. Its a jeep club based in NH. Lots of local wheeling and wrenching info and activities.
nasnop is offline
post #3 of 4 Old 03-08-2008, 08:38 AM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
Not really that big of a deal. Get a used cross member from local recycler and maybe you could just drill out the busted nuts and thru drill frame and use longer bolts that go all the way thru frame.
kevyj87 '87 I6 5spd, 215,000+ miles, Herced, Nuttered, Weber, HEI, RE 4", 1" BL, 4:11's, np231, 33x12.5's, SYE & shaft, 1" brown dog mm, home made bumpers front & rear, Ramsey 8,000lb winch
King03Kev is offline
post #4 of 4 Old 03-08-2008, 08:39 AM
pacodelahoya
1987 YJ Wrangler
http://cgi.ebay.com/ebaymotors/jeep-...spagenameZWDVW
There's your skid plate, better hurry, two hours left as of this posting.
The fix itself is no big deal if you or buddy can weld, plenty of threads about it.
'80 CJ 5 w/360
87 Wangler build in progress 350, 350, np205, 5.38 gears, soa,d60/14 bolt,accepting donations for wheels and tires(just kidding)
2000 Grand Cherokee LTD w/4.7
Do they have AA for Jeeps?
pacodelahoya is offline
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 12:34 PM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
Rusted frame..can it be fixed/welded? DamonsYJ YJ Wrangler Technical Forum 3 10-06-2008 05:34 AM
Frame fixed and I am tired but have new question molsenice YJ Wrangler Technical Forum 17 03-12-2008 04:32 PM
How diff is TJ windshield frame and YJ frame? darioc YJ Wrangler Technical Forum 6 02-09-2008 04:30 PM
