need a fpr with weber 38/38 - JeepForum.com
post #1 of 4 Old 01-08-2011, 04:27 AM Thread Starter
YJFreak
YJFreak is offline
post #2 of 4 Old 01-08-2011, 08:16 AM
coleslaw
1987 YJ Wrangler
The fpr is needed for the Weber as the presure for stock is around 5 and the Weber requires between 1.5 and 3. You can put in a clear fuel filter before the fuel pump, put in the fpr between the fuel pump and old filter and then use a "T" to replace the old metal filter. I would leave the feed back in place as this is a way for the carb to deal with vapor, excess fuel, etc.
Coleslaw
A country that tries to spend itself to prosperity is like a man standing in a bucket and trying to lift himself by the handles.
Winston Churchill
87 YJ I6, nuttered and rushed, 2.5" lift, 31x10.5, custom made f&r bumpers, Mojave heater, TJ flares, Superwinch S9000, hm swingout tire carrier, tool drawer, custom electical control, and more in the works...........
coleslaw is offline
post #3 of 4 Old 01-08-2011, 11:02 AM
gbeltran
With the return line in place you shouldn't need a FPR, I'd run it without and see if fuel drips out of the carb boosters. You aren't contemplating one of those glass fuel filters are you, I'm talking about one of those cheap ones that you unscrew to replace the element, I'd steer clear if you are, seen too many leak.
gbeltran is offline
post #4 of 4 Old 01-08-2011, 08:12 PM Thread Starter
YJFreak
YJFreak is offline
fuel pressure regulator , weber , weber carb
some weber questions for weber users giggityjeeper YJ Wrangler Technical Forum 12 06-09-2010 10:24 PM
Weber 34 DGEC Versus the Weber 32/36 DGEV FrankieCarbone YJ Wrangler Technical Forum 24 03-06-2010 10:33 AM
To Weber or Not To Weber, THAT is the question. Delta347 YJ Wrangler Technical Forum 4 01-17-2009 07:29 PM
need weber help please 05LjNj YJ Wrangler Technical Forum 10 06-25-2007 04:23 PM
Weber 32/32 packinheavy YJ Wrangler Technical Forum 0 03-13-2007 01:18 PM
