Need to find Speedometer Cable..? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Need to find Speedometer Cable..?
Steering Y-Link Adapter!Ruffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 01-07-2010, 08:15 PM   #1
fishmanwill
1987 YJ Wrangler
My speedometer cable broke and I cant find one to replace it. I have a 1987 with the BA 10/5 transmission and the NP207 transfer case. I need the speedometer cable that is metal and screws on to the transfer case, but then on the back of the speedometer I need the one end that is plastic and just pushes on the back and a small clip on the plastic part locks it in place. I cant find that one. All the stores here have the one listed that has the metal screw on ends on both ends. I looked at about 8 different years and models and none would fit. I looked at Napa, autozone, oreileys. Where can I find one or is there a different vehicle I can get it from? Thank you for the help.
Will
1987 Wrangler
4.0L swap, AX-15 swap, and NP231
fishmanwill is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 08:19 PM   #2
Fhajad
Sure the double metal ended one won't work?
I mean, I'm sure it wouldn't be the only one available if there were other ones.
Fhajad is offline   Reply With Quote Quick reply to this message
Unread 01-07-2010, 08:41 PM   #3
fishmanwill
1987 YJ Wrangler
all the ones that they had were the ones with the metal ends on both ends and I should of specified but they are the metal ends that all screw on(threaded). The one on mine is the one that has the threaded metal end on the transfer case and the clip on plastic end on the speedometer. Sorry I did not specify in the first post. Thanks,
Will
1987 Wrangler
Unread 01-07-2010, 08:44 PM   #4
Mark05059
I can look at my 89 tonight... I need to pull the speedo out anyway... its the end at the speedo head thats the problem correct?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 06:52 AM   #5
roadglide
1987 YJ Wrangler
try jeep 4x4center.com. or google it . I bought one for my 87, I just don"t remember where I got it.
roadglide is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 07:33 AM   #6
idaholtby
Here is one on e-bay that may work. This guy has a couple of them listed. The one on the left looks like it would work if the length is correct.
AMC AMERICAN MOTORS JEEP DODGE MOPAR SPEEDOMETER CABLE:eBay Motors (item 360222894370 end time Feb-01-10 17:52:58 PST)
If this one isn't correct, I would still contact him and let him know what you need.
idaholtby is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 07:36 AM   #7
93jeepyj
If its the internal (moving) part of the cable that broke it can be replaced, auto zone or maybe advance had a universal kit in the "help" section that gives you a legth of a cable you cut to length and crimp on ends. They actually work quite well and are cheaper then a whole new assembly.
93jeepyj is offline   Reply With Quote Quick reply to this message
Unread 01-08-2010, 08:55 AM   #8
bhartwell59
1987 YJ Wrangler
i have the same set up you have (BA, 207 case)... i replaced my speedo cable thru quadratec. don't know if they still have them.
forget the stores this'll be a special item
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2010, 04:41 PM   #9
fishmanwill
1987 YJ Wrangler
Had to special order it. I found a company after searching for a week online and making phone calls that sells it. RockAuto had it. 4WD and Quadratec doesnt carry it. It is not a common one. It has the nut connector and the plastic connector and it is 96"long. So hopefully it will be here this week and I can check it. Thank you for the help.
Will
1987 Wrangler
Unread 01-17-2010, 05:30 PM   #10
Mark05059
my 89 did have one however I didnt realize that when we took the body off that we chopped the cable since it was in the way.. my 89 2.5l has the same setup
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Unread 01-01-2015, 06:20 PM   #11
truckinsquirrel
Go here. i found the upper speedometer cable for my '89 Cherokee
truckinsquirrel is offline   Reply With Quote Quick reply to this message
Unread 01-01-2015, 06:52 PM   #12
Mark05059
Welcome to the forum. You have just revived a 4 year old post. I would guess the OP has solved his issue by now
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
