Need Everyones Opinion - JeepForum.com
post #1 of 12 Old 02-25-2009, 01:11 PM Thread Starter
Allen52105
Hello,
I have a question. Right now my jeep sits with a 4" lift and TJ flares and I am running 33x12.50 cooper discovery MT tires. They are basically new(1000 miles). I have a chance to trade someone my tires and rims(MT alloy) for his 35x12.50 Centennial Campaigner M/T on a set of black steel rims(red and blue strip. his tires are at about 75-80%. who would do this trade? will I rub? Or I have a guy who is going to buy a set of New Soft 8's(black obviously) who wants a rim trade. he is going to pay for the swap
thanks
jason
jason
Allen52105 is offline
post #2 of 12 Old 02-25-2009, 01:16 PM
brc94yj
I wouldn't do it. You are giving up newer tires and more expensive rims.
(I don't know if they'd fit or not)
94 YJ, Red, 4.0, Hardtop, Full doors, 4" RC lift, 31" tires
Red Jeep Club Member #518
brc94yj is offline
post #3 of 12 Old 02-25-2009, 01:16 PM
oompaloompasc3
will you rub very little... the tj flares give you alot of clearance maybe bump it up with a 1 inch daystar BL....
I would want just a little extra cash on top considering your are brand new.. what are his tires worth plus rims and what are yours worth...??? got to look at it that way...
also what do you do with it? 35's can be very hard on a jeep that is not set up properly....
1994 Jeep Wrangler SE 4.0 manual, AEM Brute Force Cold Air Intake, Red Optima, Banks Chip, Banks Header, Custom Downpipe, Flowmaster 50 Series, 35x12.50.15 BFG All Terrains, Black Steel Wheels with Simulated Beadlock, 3" Rancho Suspension, 3" BL, 3/4" brandon_yj Shackles, Line-X everywhere, So much more to do....
oompaloompasc3 is offline
post #4 of 12 Old 02-25-2009, 01:24 PM
firefighter315
I wouldn't do it unless the extra tire diameter and MT tread pattern are worth the value difference to YOU based on how you wheel your Jeep. You could probably sell your tires and then just upgrade to a MT model in a 33 for a little more $$$ and not have to worry as much about rubbing. Then you get to keep your rims.
My YJ Build Thread
firefighter315 is offline
post #5 of 12 Old 02-25-2009, 01:24 PM
OneCleanYj
By chrome, do you mean your Mickey Thompson's are polished alloys? Or a chromed steelies? Only reason I ask is because I went from having steelies to alloys and won't ever go back. Granted I have a 4 cyl, I gained a bit of power back and handling/braking improved with the decrease in weight.
You'll for sure need a 1" BL on top of the TJ flares. It's the exact set-up I'm running (minus TJ flares up front) and I rub up front, considering how much I rub TJ flares won't even give me enough clearance. Close, but not enough...
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline
post #6 of 12 Old 02-25-2009, 01:29 PM Thread Starter
Allen52105
my rims are the alloy not crome and I have a 4.0 ho motor
jason
post #7 of 12 Old 02-25-2009, 01:35 PM
RikRotorhead
Depends on your gears too. thirty fives take some lower gearing to roll. Four tens at least, or say goodbye to fifth gear.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #8 of 12 Old 02-25-2009, 02:00 PM
firefighter315
Or for anyone else reading with a 2.5L, 35s, and 4.10s........go ahead and say goodbye to 5th gear......
My YJ Build Thread
post #9 of 12 Old 02-25-2009, 03:22 PM Thread Starter
Allen52105
and I do have 4.10's
jason
post #10 of 12 Old 02-25-2009, 03:50 PM
TJlady
if you do trade...i would definitely add some height!
'99 TJ
4.5" Rubicon Express Short Arm lift, JKS 1.25" BL/MML, D44's with 4.88's and ARB's, Longfiled axle shafts- front, Superior axle shafts -rear, 35" KM2's on Allied beadlocks, NV241, Rokmen gas tank skid, Gen Right rockers and corner panels, Warn Powerplant winch, Currie heavy duty steering w/Doetsch Tech stabilizer
'07 4-Door JK Rubicon - BONE STOCK (for now)
TJlady is offline
post #11 of 12 Old 02-25-2009, 05:26 PM
OneCleanYj
I'd still keep what you've got. The set-up you have now, IMO is much better looking, and worth more money. MT alloys look sick!
Even with the 4.0, you'll probably notice the difference in weight and added tire
post #12 of 12 Old 02-25-2009, 06:36 PM
shaggyjim
shaggyjim's Avatar
Ya keep the 33's bro. I think what you have is a better looking set and the Coopers I got with my Jeep ran forever.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
i need everyones opinion KeeptheJeep YJ Wrangler Technical Forum 8 11-15-2007 09:00 PM
Everyones opinion gibbyfxdwg TJ Wrangler Technical Forum 10 05-26-2006 01:39 PM
Thanks For Everyones Help!!! DestructoJr TJ Wrangler Technical Forum 4 03-23-2005 05:37 PM
Ox-Lockers, whats everyones opinion? davage TJ Wrangler Technical Forum 2 03-14-2005 12:14 AM
wanting everyones opinion desertsport TJ Wrangler Technical Forum 4 10-20-2003 01:32 PM
