Need braided steel fuel lines (from tank to frame lines) - JeepForum.com
post #1 of 5 Old 06-18-2006, 07:29 AM Thread Starter
drew2000
drew2000's Avatar
Hey Guys,
I want to run braided steel fuel lines from my fuel pump to my fuel filter.
Do you know of any place that makes them for Jeeps?
I won't know the measurements until I get the tank out, so that part kind of sucks. I'm hoping to find some place that makes them and knows what size for my make and model.
Andrew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #2 of 5 Old 06-18-2006, 07:41 AM
Damage_ctrl
R.I.P. YJ time too: TJ
Damage_ctrl's Avatar
2009 JK Wrangler
Make your own
I make lines at work all the time. Just look up Parker hose and fittings...They have stores all over the U.S., or dealers. They will get you the proper fittings, and braided hose for gasoline. You can get the fittings and they are reusable...I'm no longer a fork lift wrench but it sure taught me where to get what I needed, and fast...If you never made them before, they will show you how as well...The outer nut is reverse thread, then the other part is standard..I'm sure it will save you $$$. Oh if you don't know the threads or fittings you need, take your parts and basic guestimations for length..
Damage_ctrl is offline
post #3 of 5 Old 06-18-2006, 07:45 AM
Damage_ctrl
2009 JK Wrangler
The link, and they should have a store finder
http://www.parker.com/ead/cm1.asp?cmid=481
post #4 of 5 Old 06-18-2006, 08:15 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
http://www.mountainoffroad.com
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #5 of 5 Old 06-18-2006, 08:38 AM
jeeepguy
jeeepguy's Avatar
Originally Posted by Michigan YJ
Nice hookup.
Thank you Michigan YJ...
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
Braided Fuel Lines honda250ex YJ Wrangler Technical Forum 21 09-09-2009 09:31 AM
Fuel lines down frame only in a jeep cj YJ Wrangler Technical Forum 1 07-13-2008 08:28 AM
Stainless steel braided brake lines Thunderstrike TJ Wrangler Technical Forum 2 08-21-2007 07:09 PM
longer braided steel brake lines heezy101 TJ Wrangler Technical Forum 7 06-11-2007 02:56 PM
'04 Gas Tank Fuel Lines... thejafe TJ Wrangler Technical Forum 2 04-14-2007 11:35 PM
