Need axle help - JeepForum.com
post #1 of 18 Old 03-13-2013, 07:30 PM Thread Starter
85CJEric
Need axle help
I found this ford 8.8 on Craigslist and was wondering if it will work in my 89 YJ without much modification? The stock Dana 30 in the rear needs the differential rebuilt and I wanted to replace it with something stronger. Tell me your thoughts and suggestions. ( see attached ad for what I am looking at)
http://nashville.craigslist.org/pts/3599678516.html
"Insurance doesn't cover stupid"
85CJEric is offline
post #2 of 18 Old 03-13-2013, 07:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Anticanman is offline
post #3 of 18 Old 03-13-2013, 07:50 PM Thread Starter
85CJEric
What if I could find a Dana 44 out of a TJ Rubicon
85CJEric is offline
post #4 of 18 Old 03-13-2013, 08:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Perfect
Luck Favours The Prepared
post #5 of 18 Old 03-14-2013, 01:27 AM
lutzke21
BTW, the front is a Dana 30 and the rear is a Dana 35.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #6 of 18 Old 03-14-2013, 08:06 AM Thread Starter
85CJEric
Another thought: would a Dana 44 out of an 88 Wagoneer fit in the YJ or does it require in depth modifications?
85CJEric is offline
post #7 of 18 Old 03-14-2013, 08:28 AM Thread Starter
85CJEric
Yeah I know, My bad. I was trying to accomplish too many things at once and got distracted. Thanks
85CJEric is offline
post #8 of 18 Old 03-14-2013, 08:52 AM
SeanB95YJ
if it's an XJ Wagoneer (just like the Cherokee but usually with wood grain sides) the only mod would be to cut off and weld on new axle perches & shock mounts... the width is the same and the lug pattern is the same
if it's a Grand Wagoneer, it's the same mods regarding spring perches & shock mounts, but it's a bit wider, and the lug pattern is different (6 on 5.5")
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #9 of 18 Old 03-15-2013, 02:19 PM Thread Starter
85CJEric
I guess the resulting questions are:
1) Is it worth trying to hunt down a new axle, or just rebuild the Dana 35 differential
2) what Ford 8.8 would be better option? (from which ford as well)
3) What is the best cost effective axle that can perform on/off road with 35 in tires?
Sorry for the rookie questions, but the Dana 35 is in need of attention.
85CJEric is offline
post #10 of 18 Old 03-15-2013, 02:24 PM
SeanB95YJ
1) other than regular maintenance (brakes and occasional gear oil changes) the 35 isn't worth putting any money into if your Jeep is modified at all for large tires and/or more power
(and some might argue it's not even worth the maintenance)
2) 8.8 out of a 95-2000 (or maybe 2001) Ford Explorer, Mercury Mountaineer or Mazda Navajo is what you want... larger axles (31 spline I believe) and disc brakes
3) see #2
swap/build thread:
post #11 of 18 Old 10-20-2013, 09:48 AM
fishadventure
Great stuff!
Confused slightly by the chart on the rangerstation link however. The diagram shows 51" but I think it means 5'1" or 61" according to this previous thread on the 8.8 whereas the Dana 35 appears to 58-1/2" wide. Can someone confirm these numbers?
Also, it appears that the Exploder 8.8 from a '95 through '01 has disc brakes, is limited slip, and is factory with 4.10 ratio. Other searches seem to concur. Any thoughts on this?
Basically, what started as a simple cheap motor swap from a 2.5 to a 4.2/258 has gotten pleasantly out of hand and I need to start a build thread I suppose. The development so far has basically been recorded here.
Since I have gotten to the point of obtaining an SYE, a front axle from an XJ, and an entire drivetrain upgrade, I decided that longterm I would be better off to do an axle swap and complete an SOA in the course of the work rather than doing the work "twice." Right now all I need is an 8.8 and I will make my own modified XJ front driveshaft to the correct length for the rear of my YJ (a local shop will balance it).
To summarize my questions/data:
  1. Ford 8.8 is only about an inch wider per side than the OEM Dana 35 (61-inches for the 8.8 and 58.5 or 58.75 for the Dana 35)?
  2. The 8.8 has disc brakes with the same bolt pattern as the '91 YJ?
  3. The D2 axle code indicates 4.10 ratio
  4. The D2 8.8 is a factory Limited Slip diff
  5. The '95- '01 F8.8 has 31-spline axles making it hugely rugged for a DD/part-time trail rig
Thanks for the great info here!
fishadventure is offline
post #12 of 18 Old 10-20-2013, 12:24 PM
Apollo12227
1. Yep, width issue isn't an issue.
2. Yes
3. Yes
4. Yes. Code 42 is preferred so that lunchbox lockers can be used without carrier replacement.
5. Yes.
Apollo12227 is offline
post #13 of 18 Old 10-20-2013, 01:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Its an inch narrower than the Dana 35. Maybe more.
post #14 of 18 Old 10-22-2013, 07:43 PM
fishadventure
Ok.I was told it was wider than the D30...
On further searching (using Yahoo! not jeepforum search...) the FAQ states the overall width is 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
I looked here and found this data on the 8.8:
Width: 59.625" to 65.6" while the Dana 35 is listed as 60.5 inches.
So I guess those are "some answers"
I am so grateful for the knowledge base here and all the FAQs - even when you search hard and can't find what you are looking for it's probably still here somewhere!
post #15 of 18 Old 10-22-2013, 09:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If we are talking explorer 8.8 it is narrower. The f-150 or bronco 8.8 is wider. And weaker.
