-   -   Need axle help (http://www.jeepforum.com/forum/f12/need-axle-help-1493036/)
85CJEric 03-13-2013 08:30 PM
Need axle help
I found this ford 8.8 on Craigslist and was wondering if it will work in my 89 YJ without much modification? The stock Dana 30 in the rear needs the differential rebuilt and I wanted to replace it with something stronger. Tell me your thoughts and suggestions. ( see attached ad for what I am looking at)
http://nashville.craigslist.org/pts/3599678516.html
Anticanman 03-13-2013 08:32 PM
Pass
http://www.therangerstation.com/tech_library/Axles.html
85CJEric 03-13-2013 08:50 PM
What if I could find a Dana 44 out of a TJ Rubicon
Anticanman 03-13-2013 09:47 PM
Perfect
lutzke21 03-14-2013 02:27 AM
BTW, the front is a Dana 30 and the rear is a Dana 35.
85CJEric 03-14-2013 09:06 AM
Another thought: would a Dana 44 out of an 88 Wagoneer fit in the YJ or does it require in depth modifications?
85CJEric 03-14-2013 09:28 AM
Yeah I know, My bad. I was trying to accomplish too many things at once and got distracted. Thanks
SeanB95YJ 03-14-2013 09:52 AM
if it's an XJ Wagoneer (just like the Cherokee but usually with wood grain sides) the only mod would be to cut off and weld on new axle perches & shock mounts... the width is the same and the lug pattern is the same
if it's a Grand Wagoneer, it's the same mods regarding spring perches & shock mounts, but it's a bit wider, and the lug pattern is different (6 on 5.5")
85CJEric 03-15-2013 03:19 PM
I guess the resulting questions are:
1) Is it worth trying to hunt down a new axle, or just rebuild the Dana 35 differential
2) what Ford 8.8 would be better option? (from which ford as well)
3) What is the best cost effective axle that can perform on/off road with 35 in tires?
Sorry for the rookie questions, but the Dana 35 is in need of attention.
SeanB95YJ 03-15-2013 03:24 PM
1) other than regular maintenance (brakes and occasional gear oil changes) the 35 isn't worth putting any money into if your Jeep is modified at all for large tires and/or more power
(and some might argue it's not even worth the maintenance)
2) 8.8 out of a 95-2000 (or maybe 2001) Ford Explorer, Mercury Mountaineer or Mazda Navajo is what you want... larger axles (31 spline I believe) and disc brakes
3) see #2
fishadventure 10-20-2013 10:48 AM
Originally Posted by Anticanman (Post 15130470)
Great stuff!
Confused slightly by the chart on the rangerstation link however. The diagram shows 51" but I think it means 5'1" or 61" according to this previous thread on the 8.8 whereas the Dana 35 appears to 58-1/2" wide. Can someone confirm these numbers?
Also, it appears that the Exploder 8.8 from a '95 through '01 has disc brakes, is limited slip, and is factory with 4.10 ratio. Other searches seem to concur. Any thoughts on this?
Basically, what started as a simple cheap motor swap from a 2.5 to a 4.2/258 has gotten pleasantly out of hand :) and I need to start a build thread I suppose. The development so far has basically been recorded here.
Since I have gotten to the point of obtaining an SYE, a front axle from an XJ, and an entire drivetrain upgrade, I decided that longterm I would be better off to do an axle swap and complete an SOA in the course of the work rather than doing the work "twice." Right now all I need is an 8.8 and I will make my own modified XJ front driveshaft to the correct length for the rear of my YJ (a local shop will balance it).
To summarize my questions/data:
  1. Ford 8.8 is only about an inch wider per side than the OEM Dana 35 (61-inches for the 8.8 and 58.5 or 58.75 for the Dana 35)?
  2. The 8.8 has disc brakes with the same bolt pattern as the '91 YJ?
  3. The D2 axle code indicates 4.10 ratio
  4. The D2 8.8 is a factory Limited Slip diff
  5. The '95- '01 F8.8 has 31-spline axles making it hugely rugged for a DD/part-time trail rig
Thanks for the great info here!
Apollo12227 10-20-2013 01:24 PM
1. Yep, width issue isn't an issue.
2. Yes
3. Yes
4. Yes. Code 42 is preferred so that lunchbox lockers can be used without carrier replacement.
5. Yes.
Anticanman 10-20-2013 02:21 PM
Its an inch narrower than the Dana 35. Maybe more.
fishadventure 10-22-2013 08:43 PM
Ok.I was told it was wider than the D30...
On further searching (using Yahoo! not jeepforum search...) the FAQ states the overall width is 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
I looked here and found this data on the 8.8:
Width: 59.625" to 65.6" while the Dana 35 is listed as 60.5 inches.
So I guess those are "some answers"
I am so grateful for the knowledge base here and all the FAQs - even when you search hard and can't find what you are looking for it's probably still here somewhere! :highfive:
Anticanman 10-22-2013 10:27 PM
If we are talking explorer 8.8 it is narrower. The f-150 or bronco 8.8 is wider. And weaker.
The time now is 02:43 AM.
