need advice on synthetic line installation - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > need advice on synthetic line installation
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 03-22-2014, 04:52 PM   #1
Dwarf
1987 YJ Wrangler
Howdy,
I got a warn 8000 with a synthetic line. They provide a zip tie to pull the line through the roller, but it is IMPOSSIBLE. I've used several zip ties and even some rubber coated steel cable and I CANNOT get the line through the roller. I can get it to almost come through and it just sticks. I have pulled with my full squat strength, bloddied my hands and forearms trying to pull this SOB through and it is not coming through. The rope came with the winch, so I think it's the right one. I am using the correct (red) end. Please let me know if there is a trick I'm missing.
I'm thinking about using some wd40, but don't want to spray anything on the line and have it corrupt the line over time.
HALP!
Thanks,
D
Dwarf is offline   Reply With Quote Quick reply to this message
Unread 03-22-2014, 05:58 PM   #2
crackedcornish
synthetic line doesn't use a roller fairlead
ETA: unless you have something like these
http://www.quadratec.com/products/92118_900X_PG.htm
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline   Reply With Quote Quick reply to this message
Unread 03-22-2014, 06:17 PM   #3
Dwarf
1987 YJ Wrangler
Drum - not roller. My bad
Unread 03-22-2014, 06:36 PM   #4
dahreno
I don't know what you mean, post pics. Especially of your forarms bleeding LOL !
dahreno is offline   Reply With Quote Quick reply to this message
Unread 03-22-2014, 08:48 PM   #5
Anticanman
Follow me
Anticanman's Avatar
Need pics.
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-22-2014, 09:41 PM   #6
bpounds
bpounds's Avatar
Here is a video. Sounds like you're already doing this, but maybe it will help to watch anyway.
http://www.youtube.com/watch?v=jhmw243q2jY
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote Quick reply to this message
Unread 03-22-2014, 09:51 PM   #7
Dwarf
1987 YJ Wrangler
Alrighty, I got everything installed and working properly. I'll post the solution for future sufferers. The zip tie provided, I'm convinced, is a stab at dry humor by the packaging engineers at warn. I found this tip on a jeep forum - a bit of all purpose grease at the input side through the drum and a coat hanger. It took maybe 5 seconds.
It's all wrapped up an ready to save me the next time I high center!
