Quantcast Need advice please (TIRE UPGRADE) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Need advice please (TIRE UPGRADE)
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 05-31-2006, 01:07 AM   #1
brcfan0142
Hey guys, i need a little advice. I have a 93 yj with the 4.0 and 6.5 inches of lift. Right now I am running 33X12.50's and I want to go to 35X12.50's. Do i need to upgrade anything on the axles or anything like regear? I don't beat my jeep up and the only time it sees 4X4 is in the winter time. So since I don't run my jeep hard or mud it, could I stay with my factory gearing when I upgrade to 35's? I' m hoping I can get 35's without any upgrades because the tires are gonna break the bank by themselves. So what ya'll think? Thanks
brcfan0142 is offline   Reply With Quote
Old 05-31-2006, 01:43 AM   #2
sreno0207
2011 KK Liberty
imguessing you still have the ****ty d35 undeer the rear? answer is YES! unless you want to blow your rear apart about 15 feet down the road i would DEF. upgrade the axles im suporsed that they didnt blow with the the 33's. hell i blew mine with 235's. i would go up to atleast a d44 or even better a 8.8 out of an explorer as for gears im not your man for that but im sure someone else will give you that info. but without regearing i would say bye bye to all of 5th gear and some of 4th. and hello to even worse MPG. Also i would really run 35's on a DD your gonna get alot of wandering and loose all arund road manners. just my 2 cents....to each his own...
sreno0207 is offline   Reply With Quote
Old 05-31-2006, 01:50 AM   #3
fratis
fratis's Avatar
if it only sees the street then the factory gears and axles will be fine. it will suck to drive but it will work. why would you want 35s if you have no intention to take it off road? it will only drive worse and get worse gas mileage and you wont even be taking advantage of the whole reason to "upgrade." besides jeep drivers "in the know" will make fun of it - a spik-n-span polished jeep with 35s and factory driveline.
fratis is online now   Reply With Quote
Old 05-31-2006, 03:02 AM   #4
92 Green YJ
Head Brewmaster
92 Green YJ's Avatar
35s on stock gears. you wont be happy with that set up for long. you're gonna lose a decent amount of power with those meats. Also as mentioned, the Dana 35 wont live long with 35s, especially not if you have it locked. I recomend an 8.87 rear end and re-gear to 4.10s
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Old 05-31-2006, 10:47 AM   #5
mjs812812
I have a 91 yj with a stock D35 and 33x12.50 tires since the day I bought it, and 90k plus miles later I've never had a problem.
mjs812812 is offline   Reply With Quote
Old 05-31-2006, 11:02 AM   #6
bokey
New Axles? Absolutely! An open D35 pulling that much weight is going to kill it. As said before, I would go to a junkyard and get an 8.8 out of an explorer; it should be somewhat cheap. For gearing, check out this:
http://www.4lo.com/calc/geartable.htm
Google does wonders lol
BTW, how come you did all this work to your jeep, but don't take it off road? Personally, I don't understand why one would big lifts, tires, etc. and not take it off road. Not trying to bust your chops, just wondering!
'94 Wrangler - Traded
'87 Trans Am - SOLD
'99 Cherokee Classic
bokey is offline   Reply With Quote
Old 05-31-2006, 11:29 AM   #7
z71offroader
my suggestion since u dont want to spend too much is to buy a 8.8 ford axle with 4:10 gears with the limited slip in it and find a front dana 30 out of a 4 banger yj that has 4:10 gears in it. ull have a strong rear axle, a limited slip in it, disc brakes, and itl beat the hell out of having 3:07s now. 4:56s would be better than 4:10s but 4:10s are better than 3:07s and a dana35, i would def not waste money regearing the dana35.
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more.
07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come!
(Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more.
z71offroader is offline   Reply With Quote
Old 05-31-2006, 11:39 AM   #8
schitzangiggles
King of Mac-istan
schitzangiggles's Avatar
Your engine/clutch will like you better if you regear. You will see 5th gear again try here for a good tire size/gear ratio chart http://www.4wheelonline.com/superlift_tiresize.htm
This one is cool
http://www.4lo.com/4LoCalc.htm
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote
Old 05-31-2006, 02:55 PM   #9
brcfan0142
I think I'll stay with 33's, lol. Thanks for all the information guys.
Old 05-31-2006, 04:02 PM   #10
jeepnekkid01
don't give up quite yet, brcfan0142...
I bought a 93 YJ a few years ago that had stock driveline, 4.0L, 3.07 gears, and 35x15.50 Swamper SXs on it. The previous owner used it for his daily driver, and I used it some just to tool around in. It went about 40k miles with those tires and never had a problem. Granted, it wasn't wheeled much, but it rode ok, drove ok, and looked good. As mentioned earlier, forget 5th gear. It was liveable as a street ride, should work good in the snow, but don't expect to crawl or mud far.
jeepnekkid01 is offline   Reply With Quote
Old 05-31-2006, 09:32 PM   #11
RIGSBN8R
All that matters is when you get new tires, you get Thornbirds. Those things are so bada$$. I'm saving up so I can get a set of 31s!
[url]www.georgiajeeps.com[/url]
RIGSBN8R is offline   Reply With Quote
Old 05-31-2006, 11:18 PM   #12
Ryanpowell167
I cant tell if this guy is serious or not....
Ive had 35's on my d35 for more then 7k miles and i wheel pretty moderatly. Once every few days climbin chit. Im hard on it. Ive got the 4banger and 4.10s' and i do ok on the street and liveable on the highway. I can hit 60 on flat ground. You guys think the d35 is just total garbage dont you? Its not as bad as you think. Everyone jumps all over it as the worst axle ever made. As long as you not wheelin it, you will be perfectly fine. With the i6 you should be the same as me. If you want to be able to peel out(8.8 req for this ) then youll want to regear.
ITS NOT THAT BAD GUYS!
DARK STONE 2005 6.0l v-8 PowerStroke F-350
BLACK 1992 YJ 383Stroker, TH350, looking for a np205, d44 front, 12bolt rear, SOA on 4" springs, 35" Baja Claws, m8000, Electric fan, sliders, bumpers, crossmembers, all made by myself.
Black Jeep Club Member #167
Ryanpowell167 is offline   Reply With Quote
Old 06-01-2006, 02:41 AM   #13
92 Green YJ
Head Brewmaster
ummm, i hope you are joking. sure they look good, but they aren't called thornturds for nothing. they are one of the WORST performing tires on the market. they wear bad, they are loud as hell on the street, and they SUCK offroad
Old 06-01-2006, 02:52 AM   #14
schitzangiggles
King of Mac-istan
Yeah except for the half dozen I have had to help fix. factory defects/seconds I guess.
What is "I wheel pretty moderately... I'm hard on it." mean?
Toss in a locker and see what happens. Leave it open you should be ok, but I have seen one break in the mall parking lot (not kidding) so wheel moderately at yer own risk...
-Samual Adams
Thomas Jefferson
Mac Wilson
Glock Forum
