Need advice on motor mount lift and body lift - JeepForum.com
post #1 of 2 Old 07-06-2008, 10:39 PM Thread Starter
learfxr
I have a different transmission/case combo than most. My NP208 hangs down and I've built a metal shield around it, but it sucks for clearance. I'm thinking about a 2" lifted motor mount and a 2" body lift. That should let me level things out a bit better. Any tips? Any thing to consider? BrownDog has the mounts for 1" or 2" motor lift. I personally don't like body lifts, but since I can't afford an Atlas, it's what I feel I must do. Please let me know, I'm ready to start ordering parts soon to get started if this is the path I need to go.
89 YJ TBI350 TH350 203/300 Rocks and 43's in work
00 TJ 8.8 swap, 35's and 4.88's
learfxr is offline
post #2 of 2 Old 07-06-2008, 11:21 PM
wroose
One of the thing i run into while doing my engine swap was t-case angle, advance adpater makes a clocking ring so you can change the angle of the t-case, ie: move it up and out of the way. cheap way to go, and work great. body lifts suck, only lift the body if you have too.
Bill
wroose is offline
Body lift, Motor mount lift questions Hoofguy TJ Wrangler Technical Forum 15 07-06-2012 06:22 PM
Body lift/ Motor mount lift. Im confused Nates93yj YJ Wrangler Technical Forum 9 06-11-2009 06:39 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 09:04 PM
Questions regarding Body Lift and Motor mount lift ToddEdge TJ Wrangler Technical Forum 5 11-26-2007 01:52 PM
Body lift motor mount lift clarification Freakshow TJ Wrangler Technical Forum 8 11-20-2005 09:43 PM
