-   -   need advice (http://www.jeepforum.com/forum/f12/need-advice-1505757/)
jmet87yj 04-07-2013 06:36 PM
need advice
Need help on idle problem..i have an 87 yj 2.5any way im new to jeeps an can not figure out why my jeep is loading up an spitting an sputtering an dies while idling can someone tell me why it does this an how to fix it.. thanks..
superj 04-07-2013 06:55 PM
Does it have a carb or fuel injection?
jmet87yj 04-07-2013 09:27 PM
I want to say it has TBI because it only has one injecter on it but i am new to jeeps an that maybe what your calling fuel injection.
Que89YJ 04-08-2013 09:20 AM
The likely reason is too much fuel. Is there a difference hot/cld? The ecu direguards the O2 sensor until it reaches operating temp. Then the ecu uses the O2 sensor to figure out how much gas to use. If you are loading up with gas then O2 sensor is the first place to start. The other common reason is the exhaust manifold gets cracked especially down by the collector tubes or the manifold bolts get loose. It allows air into the exhaust and the O2 sensor tells the ecu that its lean and dump more gas.
jmet87yj 04-08-2013 12:00 PM
Ok thanks alot i will check exhaust an replace the o2 sensor.
EABiker 04-08-2013 01:31 PM
Also check all your vacuum lines for leaks; they can throw the O2 sensor into a tizz. Remember, the O2 sensor does not come into play at all until the engine reaches operating temperature. If your Jeep acts this way only when cold, it's not the sensor.
The time now is 05:37 AM.
