#436 | |
![]() I had Arch_Angel make it Thanks Justin
NATE 2004 Jeep Wrangler Columbia Edition DD and Trail Rig 1993 Jeep Wrangler Nates93yj BuildSOLD |
#437 |
do those tube fenders you have match up with your body on the bottom? ive onyl seen one other jeep with them and the seemed short
It's not what you buy, it's what you build and what you do with it |
#438 |
Not mine, i made mine. so i could have lined it up but i didnt care
#439 |
i realized that after i said it yours loook much better then the ones i looked at
#440 | |
I helped design them for this guy YJ Jeep Tube Fender Conversion Kit Wrangler
#441 | |
#442 |
I Like them but im probably going to end up redoing them or selling them. Because i would like to make some high line fenders
#443 | |
#444 | |
Here are some more wheeling photos ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#445 |
good pictures the highline fenders are quite pricey esp. the ones for up front thats why i was just going to do the rear because they were much cheapen than the front
#446 |
Bought a PA 1 inch body lift for $40 never used, couldnt pass it up and i need it for the belly up.
Also replaced the throttle position sensor and motor mount. It would idle up to 3 grand and run like ****. Now it purrs. I also i got ahold on some mtrs that are grooved and only used 1 run from a guy that uses them in races. He wants a $100 a peice. Different sizes 32x11.50, 33x12.50, i think 35s too but i think i might go with 33s when i can get ahold of this guy
#447 |
took the top off and doors off
![]() Bought a 4 foot firestik cb whip have a noise in the front end, im thinking its a wheel bearing. And i also have a my pinion bearings are out of my d35 its pretty bad and there is a good amount of slop. 8.8 might come sooner than i thought. Changed both axle joints thanks Nate
#448 |
Just bought a 8.8 with 4.10s and a limited slip for $150 which is a steal around here. Hopefully ill be installing it soon because my pinion bearing is going out in my D35
#449 |
nice find on the 8.8. I've been keepin my eyes peeled for one around here but no luck so far.
Build Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15 WTT: 4" springs for 6" WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask |
#450 |
Well i broke a u joint on the passenger side of the axle shaft. So im probably going to use XJ shafts that i have sitting in the garage with the 260xx u joints not the 297xx. Idk what im going to do yet. i would like to get a waggy 44 but i want to retain the 5x4.5 so i might go with cromolys with life time warrenty.
Im just disappointed that i broke them with 31s and a 4 cylinder ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
