Name That Tranny... - JeepForum.com
post #1 of 20 Old 07-16-2012, 10:36 PM Thread Starter
codymiguel
1987 YJ Wrangler
Name That Tranny...
Ok I know that My 87 Yj with the 4.2 has the BA10/5 tranny in it, but I have a 89 4.2lt with a tranny attached to it and also know that they used two different transmissions that year the BA10 and the AX15.
I have seen pic's of the AX15 but it does not look like it. I have a BA10 that has does not look like that either. SOOOOOOO I am stumped.
The Transmission on my BA10 has fill and drain holes on the side of it and this is the reason that I came to the idea that these are not both BA10's.. But the other transmission does not resemble the AX15 at all.Any other trans used that year or might be some other swap other than a AX15 that also has a Internal slave. .. Would their be a plan of attack to figure out what trans this is ????
Thanks For Reading
Cody
codymiguel is offline
post #2 of 20 Old 07-16-2012, 10:53 PM
yjsmoghater
I have an 89 with a ba10 and my transmiision drain plug is facing the rear of the jeep right in between the mount and xfer case not on the side like the fill plug. The fill plug is on the passenger side about halfway up the trany. This is a pugeot Ba10 in my 89 with the 4.2l
yjsmoghater is offline
post #3 of 20 Old 07-16-2012, 10:57 PM Thread Starter
codymiguel
1987 YJ Wrangler
Well maybe that means that the BA10 came with different cases ??
post #4 of 20 Old 07-16-2012, 11:01 PM Thread Starter
codymiguel
1987 YJ Wrangler
My trans has two plugs on the side that i believed to be the drain and fill plug. No plug to speak of on the rear. AND the one that came out of the 89 that does not look like a AX15 had NO drain or fill holes on the side
post #5 of 20 Old 07-16-2012, 11:36 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
This thread is useless without pictures...
Michaelgoesrawr is offline
post #6 of 20 Old 07-17-2012, 12:05 AM Thread Starter
codymiguel
1987 YJ Wrangler
Yeah i have thought about that but the only one I have is crappy... Will roll by my friends house where my motor is and snap a few pic's tomorrow and look some some markings on the trans to further help identify the mystery tranny. Just have exhausted myself with google and my searches on images of ba and ax transmissions trying to figure this out.
Will take stab two at it tomorrow. Till then my only crappy photo of the trans and motor
post #7 of 20 Old 07-17-2012, 01:04 PM
moonpie312
Can you get a better photo of the tranny itself? Does the case split on an angle or straight up and down?
moonpie312 is offline
post #8 of 20 Old 07-17-2012, 05:33 PM
Jax89Jeeper
That looks like a ba10 to me... Based on the shifter, small size, and it looks like it splits on its length.
Jax89Jeeper is offline
post #9 of 20 Old 07-17-2012, 08:10 PM
trboxman
1987 YJ Wrangler
I concur that it's a BA10/5.
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #10 of 20 Old 07-17-2012, 10:30 PM Thread Starter
codymiguel
1987 YJ Wrangler
it splits down the middle on how it is put together and i know the BA10 is but The issue is that i have TWO 4.2 motors and TWO transmissions that can not both be BA10's because they have different housings. At least that is what was told me by my local Jeep Shop. The Transmission I have in my Jeep now has the fill and drain holes on the side that both take a square 5/16th bit. But the Transmission that is on the other motor has no drain plugs on the side so that leads me to believe that it is different.
The only other transmission that Max at MOAB said that it is likely to be is the T5
post #11 of 20 Old 07-17-2012, 10:38 PM Thread Starter
codymiguel
1987 YJ Wrangler
one more picture
post #12 of 20 Old 07-18-2012, 02:30 AM
yjsmoghater
That looks like a ba10/15. This is what i have in my 89. It looks the same to me and i have put all ba10 parts on it(shifter, slave cylinder) and they match up perfect.
pic 1 is pass side from front, fill plug directly below shifter
pic 2 pass side rear, fill plug to left of square tag
pic 3 driver side actually taken thru hole in the crossmember, theres the drain plug hard to miss
pic 4 driver front, transfer case shifter and slave line & bleeder
looks like u need to dig thru some grime to find your fill/drain plugs
those plugs are some metric size i believe, tried grinding 3/8 down to fit but snapped so found a random punch that fit perfectly so got lucky
damn Peugeot im scrappin this thing the 1st chance i get
ForumRunner_20120718_012404.jpg   ForumRunner_20120718_012503.jpg   ForumRunner_20120718_012551.jpg
post #13 of 20 Old 07-18-2012, 08:45 AM
Jax89Jeeper
That looks nothing like a T5 trans. I am certain you have the BA, it is what came in the first half of 89 from the factory. So unless it was swapped for some trans other than those known to fit the late AMC 4.2, its the BA. It is not the T5, AX15, or either of the NV's....
post #14 of 20 Old 07-18-2012, 09:18 AM
pete1991YJ
"Sheila" is a good name for a tranny...
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #15 of 20 Old 07-18-2012, 02:57 PM Thread Starter
codymiguel
1987 YJ Wrangler
Ok well if it is the BA then I will have to take pictures of the transmission on my jeep now because the outer casing is different than the one in the pictures.
ax15 , jeep , transmission
My tranny shop called and tranny is toast...... happy1426 YJ Wrangler Technical Forum 6 08-30-2011 12:35 PM
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 06:11 AM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 06:10 AM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 08:16 AM
How much heavier is an auto tranny than the manual tranny? CB3 TJ Wrangler Technical Forum 9 12-24-2007 06:35 AM
