MYSTERY of the tired old jeep - JeepForum.com
post #1 of 38 Old 04-20-2013, 02:26 PM Thread Starter
jbeebe
(lazy people skip to "summary" at the end) About 6 months ago the jeep would just not restart after shutting off. It ran perfectly, but just wouldn't restart for a few minutes. Sometimes it did it when it was hot, sometimes when cold. Then it solved itself a few months ago.
Yesterday, driving to the gym the engine hesitated a bit almost like someone pinched the fuel line for a couple seconds, then it kicked back in and was fine. But on the way home from the gym she just died while driving. Just a slow lack of power until it finally just cut out. All the electrics are fine.
I tested the fuel pressure today for the first time and primed, its at ~35, but when started it was hovering around 70. Now granted, that could have been due to the 20 dollar HF tester.
The only thing besides fuel pump that I can think of would be the cps. What do you guys think?
Summary:
Jeep would intermittently not start a few months ago, then all good.
died while driving yesterday and wouldn't start for a few minutes.
fuel pressure is 35 primed up. at idle my cheapo tester read 70, not sure if that's even possible.
I'll include a little picture just to get some people to respond to another stupid "jeep just dies!?!?!" thread.
How about this little treasure from Wal-Mart:
91 YJ. 4.0, 4.10's, 33's, 4" springs, 3/4" booms, 1" BL, 1" MML, d30 aussie locker, hand throttle, posi-lock, full cage, bumpers/rocker guards/engine skid, winch.
jbeebe is offline
post #2 of 38 Old 04-20-2013, 02:57 PM
Que89YJ
You either have a pinched return fuel line or a bad regulator. Disconnect the return line up at the fuel rail and run it to a gas can. If it is still high bad regulator. If it is normal bad fuel return line.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #3 of 38 Old 04-20-2013, 03:03 PM Thread Starter
jbeebe
If it's the regulator, do I have to replace the entire fuel pump too? All i know about the regulator is that it's in the tank with the pump. I never pulled the pump from the tank (though i have dropped it before) so i'm a little unfamiliar with it
thanks
jbeebe is offline
post #4 of 38 Old 04-20-2013, 03:04 PM
Que89YJ
the regulator is on the fuel injector rail.
Fault codes:
No Start:
post #5 of 38 Old 04-20-2013, 03:06 PM Thread Starter
jbeebe
well then let me rephrase my original statement...
" i know absolutely nothing about the regulator!"
haha
jbeebe is offline
post #6 of 38 Old 04-20-2013, 03:27 PM Thread Starter
jbeebe
where the two lines attach to the rail, is the return line the one towards the front or rear of the engine bay?
jbeebe is offline
post #7 of 38 Old 04-20-2013, 04:25 PM
Que89YJ
The return line comes off the regulator at the front.
post #8 of 38 Old 04-20-2013, 04:39 PM Thread Starter
jbeebe
got it, i'll check it out and update this thread tomorrow with my findings.
jbeebe is offline
post #9 of 38 Old 04-20-2013, 05:29 PM
Mark05059
[URL=http://s669.photobucket.com/user/casanova91787/media/walmart_zps60a2bf87.jpg.html
[/URL]
Hey where did you get the picture of my cousin?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #10 of 38 Old 04-21-2013, 11:10 AM Thread Starter
jbeebe
i followed the line coming out of the regulator (it's the line towards the front of the engine bay) and it looks like it runs into the filter, so that has to be the sending line right? Does the regulator regulate the fuel coming into the rail?
jbeebe is offline
post #11 of 38 Old 04-21-2013, 11:25 AM
Que89YJ
pull the line. turn the key. see if fuel comes out of the fuel line or the rail.
Fault codes:
No Start:
post #12 of 38 Old 04-21-2013, 11:46 AM Thread Starter
jbeebe
Well its the return line, I pulled it and drained it into a container. The pressure hovered right above 30.
I don't see how it could be pinched though, I have a 1 inch body lift and can wiggle the line on top of the tank freely
jbeebe is offline
post #13 of 38 Old 04-21-2013, 12:27 PM
Que89YJ
It can be in the tank itself. There have been several people here lately that have had the return line in the bottom of the tank touching the bottom and restricting flow.
post #14 of 38 Old 04-21-2013, 12:33 PM Thread Starter
jbeebe
That would be a whammy, I may have to drop the tank after all. I'm going to do drain from the line in the back right where the metal line meets the rubber, that way I'll find out if the blockage is in the tank or at least in the rubber line on the tank
jbeebe is offline
post #15 of 38 Old 04-21-2013, 12:39 PM
Que89YJ
You can jumper the fuel pump relay socket from 30 to 87 with a wire and use the pump to drain the tank.
