Mystery plugs behind dash. - JeepForum.com
post #1 of 4 Old 05-17-2010, 08:29 AM Thread Starter
muddy93
1987 FSJ Wagoneer
I'm in the process of re-doing the dash in my 93, and I found these two plugs behind the dash. Dose anyone have any idea what they are for, here's a couple pics, mystery plug 1.
mystery plug 2.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #2 of 4 Old 05-17-2010, 08:56 AM
Roadyy
the first one looks like the connection for the buld that is on the bottom bezel of the steering column, the second resembles the heater switch plug..
Are they both from driver side ?
Roadyy is offline
post #3 of 4 Old 05-17-2010, 09:12 AM Thread Starter
muddy93
1987 FSJ Wagoneer
Yes, both are on the drivers side. The heater works just fine(with the exception of the vent door cable, which is disconnected, and visible in one of those pics), so I don't think that second plug is for the heater.
Could it possibly be something for AC? The jeep had AC when I got it, but aparantly had a leak, and the PO ran it without refrigerant, and seized the compressor. But I don't remember seeing that plug when I removed all the AC stuff.
muddy93 is offline
post #4 of 4 Old 05-17-2010, 09:20 AM
Nitro_Man
First is a dash light, fits in plastic cover/bezel above the switch panel which would hold switches for rear defrost and rear wipers. Uses a #74 bulb. Most jeeps have a blank panel. Second plug with 5 wires is the A/C pig tail. I used this to tap into the wires for my e-fan set-up.
Nitro_Man is offline
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 09:37 PM
Daystar Dash Top Console & Rugged Ridge Dash Organizer ? tennistom1 JK Wrangler Technical Forum 3 11-17-2009 04:03 PM
Mystery Plug square five pin 93 yj dash tetvet YJ Wrangler Technical Forum 0 09-05-2009 06:26 PM
1987-1991 Dash 1992-1995 Dash Jayeep YJ Wrangler Technical Forum 9 11-13-2005 02:00 AM
Splitfire Plugs vs. Standard Plugs Alphadux TJ Wrangler Technical Forum 8 11-19-2003 07:35 PM
