Mysterious fuse box (looks like). Can someone help identify what for? - JeepForum.com
post #1 of 20 Old 04-24-2013, 06:58 PM Thread Starter
atldude
Was trying to get my seatbelt light working (yes i am bored while lady cooking lol)
And traced it to this fuse box, at least the colors of the wire match. Anyone know what these are for?
atldude is offline
post #2 of 20 Old 04-24-2013, 07:01 PM
Fenix85182
Fenix85182's Avatar
Do you mean that black fuse panel, which is the interior receiving end of the bulkhead on the firewall, or the smaller white plastic assembly underneath?
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #3 of 20 Old 04-24-2013, 07:12 PM Thread Starter
atldude
Sorry for not specifying. The small white panel.
Is this aux power or a fuse box?
atldude is offline
post #4 of 20 Old 04-24-2013, 07:14 PM
Fenix85182
Fenix85182's Avatar
Looks like something a previous owner probably added to put more fuses in the fuse block, probably for aux lighting or something. Pretty smart--I was thinking about something like this today.
post #5 of 20 Old 04-24-2013, 08:01 PM Thread Starter
atldude
Ya if this is some custom stuff it looks damn clean, i was really thinking it is something factory acc.
Thanks man!
atldude is offline
post #6 of 20 Old 04-24-2013, 08:03 PM
Fenix85182
Fenix85182's Avatar
No problem! Check for voltage and then consider it a blank canvas!
post #7 of 20 Old 04-24-2013, 09:38 PM
deathtrap
The wtite connector is were the buzzer plugs into, and likely why your seat belt light dosn't work. It is a small black box that has about 5 flat prongs on it. Alot of people remove them to stay sane.
deathtrap is offline
post #8 of 20 Old 04-24-2013, 09:51 PM Thread Starter
atldude
LOL too funny! Well that explains why the seatbelt wire went in it ... I didn't know if it was just the same color wire but i guess i wasn't dreaming it up.
Thanks man!
atldude is offline
post #9 of 20 Old 04-24-2013, 10:10 PM Thread Starter
atldude
Found the info on it. This doc has the diagrams:
http://dc378.4shared.com/doc/ceQ8Arkv/preview.html
atldude is offline
post #10 of 20 Old 04-24-2013, 10:57 PM
deathtrap
yea I use pin no 1 to power my c.b.
post #11 of 20 Old 04-25-2013, 07:04 AM
Fenix85182
Fenix85182's Avatar
No kidding! Good to know!
post #12 of 20 Old 04-25-2013, 08:49 AM Thread Starter
atldude
Played around with it some this morning. I think i can rig up something to remind me about the belt. I'm really bad about it and thelight will help. The circuits work just fine even the belt buckle switch. I'm a crappy electrician but seems like if i can get something similar to an OR gate to hook up to the ign and the belt pins that gives me hot wire if the ground from the switch is good i can plug that in directly into the lamp wire and it will work. Saw the buckle light for the first time today lol
atldude is offline
post #13 of 20 Old 04-25-2013, 09:27 AM Thread Starter
atldude
I think i just found what i need!
Apprently it is called a relay .. Told you i was a crappy electrician lol
And this is how you hook things up apparently: http://www.the12volt.com/relays/page1.asp
So the plan is to use the negative signal from the belt to trigger the 12v on the lamp. The 12 fused signal will come from the ignition pin heck i can prolly add a mild buzzer to that too lol
Time for a trip to radio shack.
atldude is offline
post #14 of 20 Old 04-25-2013, 09:45 AM
Tx91YJ
I like the idea of pulling switched power off of it! Mine was gone as well when I purchased the YJ long ago.
Tx91YJ is offline
post #15 of 20 Old 04-25-2013, 09:59 AM Thread Starter
atldude
Welcome to the forum!
I actually have the line split behind the white box goi into my rearview mirror which has dome lights. That way i can't forget them on and drain the batt.
atldude is offline
