My YJ-CJ Dash Build - Page 2 - JeepForum.com
post #16 of 48 Old 10-24-2009, 04:26 PM Thread Starter
racerx8413
Thanks for the response Jeff. I will be examining the defrost issue probably next weekend. My windshield frame does not have the vents in it, but I do have some space to work with, I may be able to put some small turn-ups on the oval openings where the wiper linkage is, to get defrost. We'll see. The pictures of your pvc ductwork though are perfect, I will definately be doing something similiar. Either pointing the vent straight up, or out, not sure which yet. I also may get a CJ dash pad and do something with it, for defrost. I spent most of today finishing up the dashwork, and cleaning up the old wiring harness that was there from before the Wagoneer motor was ever swapped into it.
I've finished it for the most part, still having slight issues with the headlight switch, and the fact that only I found only one funcitoning vent control under the dash, not sure what the others control.
^ Cut the lip off of a rubber pipe to pipe adapter from the plumbing section at Lowes. Used it around the speedometer, perfect fit. I sprayed it with rubber undercoat so that it's not quite so obvious that i have a piece of plumbing on my dash :P
I was wondering, IF anyone could identify the vent levers under the dash, and what they do on a 89 or so YJ?
There is a vacuum operated lever up next to the windshield, is this for defrost?
What are the other two exactly?
YJ
racerx8413 is offline
post #17 of 48 Old 10-25-2009, 03:44 PM Thread Starter
racerx8413
Installed the new fuel sending unit. I took the autometer sending unit, and drilled/screwed it's sensor into the same place as the old one. Works great. It could use some tweaking, a full tank shows about 7/8ths on the gauge.
I still have no vent controls. The OEM style cables, do not like being bent, so in any other install position other thatn straight back, they sit crooked in the dash, and are un-usable. I may put the stock controls underneath the dash and use the holes in the dash for something else.
I also have no headlights yet :P
YJ
post #18 of 48 Old 10-29-2009, 09:57 PM
Bromin
Let me know what you come up with for the defroster. I'm working on mine now but i do not want a dash pad. I was thinking of either swaping to a cj windshield frame or punch holes in the bottom and top of the yj frame for the defrost.
Bromin is offline
post #19 of 48 Old 10-29-2009, 10:26 PM Thread Starter
racerx8413
I ordered a CJ dash pad from Morris, and I will be doing the following...
Going to cut the stock YJ defrost vent in half, so that that air flows to the left side of the vent. I will be cutting diagonally to remove the passenger side of the defrost vent completely (it interferes with the new gauges.
Then I will cut a rectangular hole into the front of the new dash panel.
At that point, I can hopefully fabricate or turn up the defrost air through the pad, onto the windshield.
As for the control cables, I am only using one. All heat will come out of the defrost. I bought some control cables from an airplane parts shop online, perfect for the custom cable lengths, and I was even able to stick the CJ style knobs onto them. As It turns out, I'm only using one of them though, the cable goes from the dash, to the passenger floor lever, that changes from heat to vent. I may at some point decide that I want the heat to go to the floor or something, but I won't worry about that until I'm finished with everything else.
A-730 GLIDE FREE CONTROL from Aircraft Spruce
These cables are AWESOME. Very very flexible, and you can cut it to length.
YJ
post #20 of 48 Old 10-29-2009, 11:07 PM
dbabbster
I really like the textured paint you used on the dash, what kind of paint (brand) did you use?
dbabbster is offline
post #21 of 48 Old 11-02-2009, 11:54 AM Thread Starter
racerx8413
It's just Rubberized Undercoat I got from Advanced autoparts. I don't recall the brand, but they are all the same. It's just as fragile as any regular paint, it will still show scratches if you scratch it, but It looks nice.
YJ
post #22 of 48 Old 11-02-2009, 12:40 PM
jeepguy85
1987 YJ Wrangler
I am a huge fan of the Duplicolor Truck Bed coating. I tried the rubberized undercoating and it was way to fragile for my purposes. The duplicolr works very well for spraying the dash. That is what I did to my 85 CJ7s dash.
jeepguy85 is offline
post #23 of 48 Old 12-30-2009, 07:31 AM
tc89YJ
Hey Racer, where did you get the defroster vents you put on the windshield frame? I just finished my YJ dasj swap and I cant find anything like those. if you can email me back at tnkculjat@gmail.com
tc89YJ is offline
post #24 of 48 Old 12-30-2009, 10:10 AM Thread Starter
racerx8413
The holes in the windshield frame are stock, and I have yet to do anything for the actual defrost vents. I'm not too concerned about the defrost anymore as I won't be driving the jeep in weather were I need it.
YJ
post #25 of 48 Old 12-30-2009, 10:14 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
No need in Denver???
Google, CJ Dash swap, there was a good write up about a year ago, had a defroster solution, but for the life of me I can't remember what it was.
- Ernie
Richmond88yj is offline
post #26 of 48 Old 12-30-2009, 01:02 PM
Lasher242
Great work on the swap!! I'm in the process of doing mine and seeing your end results really makes me wish I had done it a long time ago....
Yellow Jeep Club #1966
Lasher242 is offline
post #27 of 48 Old 01-18-2010, 08:37 AM
r7069c
I am currently doing the same project and have the same delimma with the defrost. Does anyone make a grommet that will fit the 2 access holes in the bottom part of the windshield frame?
r7069c is offline
post #28 of 48 Old 01-18-2010, 11:10 AM
93jeepyj
a stock cj7 grommet works for the passenger side but youre on your own for the drivers side. I plan to cut a out a piece of sheetmetal to make a cover for that side someday.
93jeepyj is offline
post #29 of 48 Old 01-20-2010, 10:57 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Maybe you can cut a couple of CJ grommets and put them together to fill the hole.
John Strenk is offline
post #30 of 48 Old 02-11-2010, 11:57 AM Thread Starter
racerx8413
I covered them with dash pad :P
YJ
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Project "NO PLASTIC" Dash Build Joe1167 YJ Wrangler Technical Forum 67 03-05-2012 06:21 PM
Daystar Dash Top Console & Rugged Ridge Dash Organizer ? tennistom1 JK Wrangler Technical Forum 3 11-17-2009 03:03 PM
cj dash build antec YJ Wrangler Technical Forum 26 05-22-2009 01:05 PM
New Dash and Cage Build Thread mferrari TJ Wrangler Technical Forum 23 02-15-2008 03:22 PM
Custom Dash Build coyote_94yj YJ Wrangler Technical Forum 35 02-06-2008 06:51 AM
