My YJ to CJ-9 Conversion Thread - Page 2 - JeepForum.com
post #16 of 180 Old 02-28-2009, 08:30 PM Thread Starter
JeepsOLot
Originally Posted by SteveJcoYJ View Post
are the connectors for the headlights all the same?
you don't have a shot directly from the front, does the grille sit flush on the YJ fenders, from the sides it looks like theres a gap ?
The connectors for the headlights are the same, but NOT the ones for the turn signal lights on the grille. The CJ ones only have two wires coming out of them, and the YJ ones have four!! Thank God I have my '92 FSM, just have to look at it to see what wire goes where. I do know that someone did this on an '87, and it had three wires, two of them were like the CJ ones, but, the third was a ground wire that the CJ lights didn't have as they were grounded through the grille screws.
As for the fenders, I haven't got them pulled into the grille yet. That's going to be the last thing I do tomorrow, after getting the wiring and the radiator straight. Oh, I still have to fab the body mount for the CJ grille, can;t forget that,
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #17 of 180 Old 02-28-2009, 08:34 PM
Tompatt
1987 YJ Wrangler
Why didn't you just wait for the CJ fenders? Impatient much?
Thomas
-1987 YJ
Tompatt is offline
post #18 of 180 Old 02-28-2009, 08:36 PM Thread Starter
JeepsOLot
Yes, I should be swapping out my AX15, but, NOOOO, I just HAD to swap out the CJ stuff first, I'm dumb!!
Jerry
post #19 of 180 Old 02-28-2009, 08:47 PM
SteveJcoYJ
thats how these things usually go jerry
hopefully we'll be seeing pics tomorrow night
SteveJcoYJ is offline
post #20 of 180 Old 02-28-2009, 09:25 PM
tuckinauster
tuckinauster's Avatar
You either need a body lift, or to cut your grille down, so your hood will lay flat. CJ grilles are an inch or so taller, so you have to make up that hight somewhere.
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Its a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #21 of 180 Old 02-28-2009, 10:21 PM Thread Starter
JeepsOLot
It will lay flat, I just haven't pulled the fenders in to mate with the grille yet. I have a 1"BL on now, as well as cut out the section of the grille above the power steering lines on the steering box. One of the guys was right, you couldn't beat that 1" puck between the CJ grille mount and the YJ frame mount if you wanted to!!! That does help alot!!! On thing I noticed to, the Jeep doesn't look to have a flat nose like it did with the YJ grille and hood.
Well, I'm gone, will get you guys pics tomorrow of the finished product,
Jerry
post #22 of 180 Old 03-01-2009, 08:30 PM Thread Starter
JeepsOLot
Ok, Round 1 is complete.
With all the lights working:
Here is a pic of how close the fan clutch is to the radiator:
What does everyone think? Should I take the fishing rod rack off or not?
Round 2 will commence when the fenders show up this week sometime,
Jerry
post #23 of 180 Old 03-01-2009, 08:47 PM
93jeepyj
ooks good but ill bet youll be happier with the cj fenders. How well were you able to make the yj ones fit ? honestly I gotta say loose that rod holder and show off that sweet cj grill. maybe you could make an adapter or modify it to attach to a hitch reciever when you need it or something.
93jeepyj is offline
post #24 of 180 Old 03-01-2009, 08:56 PM
shaggyjim
shaggyjim's Avatar
Ya if you went to the trouble to install a CJ grill you might aswell show it off!
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #25 of 180 Old 03-01-2009, 08:58 PM Thread Starter
JeepsOLot
As for the CJ fenders, they are coming, and yes, I'll be much happier with them, these YJ fenders are beat up pretty good.
As for the YJ fenders, I just used sheet metal screws, three on each side, and brought them in. I did that at an angle so they would be pulled up and in at the same time. I used 2" long screws to do this.
As far as the rod rack, I'm thinking it has to go too. It sucks because a local welding shop on the Outer Banks, NC, built it for me custom, before they started to be mass-produced. But, on the other hand, it has issues, someone backed into me, and that aluminum just doesn't hold up to well to any sort of bashing. I might still keep it, maybe, like you said, make it to mount on a 2" receiver, and, then, I can take it off, or put it on when I need it,
It really does hide that grille more then I would like. I'll take it off tomorrow after work, and post more pics.
Jerry
post #26 of 180 Old 03-01-2009, 09:00 PM
oompaloompasc3
That looks really good. What does it look like without the rod holder? Also could you weld something on to it to make it a hitch for the rear? Just a suggestion....
1994 Jeep Wrangler SE 4.0 manual, AEM Brute Force Cold Air Intake, Red Optima, Banks Chip, Banks Header, Custom Downpipe, Flowmaster 50 Series, 35x12.50.15 BFG All Terrains, Black Steel Wheels with Simulated Beadlock, 3" Rancho Suspension, 3" BL, 3/4" brandon_yj Shackles, Line-X everywhere, So much more to do....
oompaloompasc3 is offline
post #27 of 180 Old 03-01-2009, 09:04 PM
sprowley
Take the rod rack off. Functional maybe, but I personally think they look horrible. And yeah, you should show off your new shiny grille, don't hide it!
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #28 of 180 Old 03-01-2009, 09:08 PM
Jkanly
Man that rod rack has to go, haha. I think you'd be happier with it in a different location, as oompaloompa said you might be able to mount it on the rear somehow? maybe you could have the same shop modify it for you?
l _____
/l
,[____],
l---L 0lllllll0-
()_)-()_)--o-)_)
Jkanly is offline
post #29 of 180 Old 03-01-2009, 09:28 PM
broken-fish
are you still in florida? if so what are you doing with the yj fenders?
broken-fish is offline
post #30 of 180 Old 03-01-2009, 10:02 PM Thread Starter
JeepsOLot
Thanks for the comments, guys! I think I'll take the rod rack off tomorrow, assuming I can get the bolts off the bumper!
As for the YJ fenders, broken-fish, there's a guy on here that asked about the passenger side fender. To be quiet honest, these fenders are not in real good shape, the passenger side one being the worst. I made that clear with pics, and he wants it still. I'll have the driver's side one available when I swap fenders, if you're still interested. I'll send you pics when I pull them, if you like.
Jerry
Anyone used the AA AX-15 conversion kit? OneCleanYj YJ Wrangler Technical Forum 0 04-09-2008 12:04 PM
Dash Led Light Conversion Thread 'B'wigstrailrig TJ Wrangler Technical Forum 3 09-21-2007 07:11 AM
5.0L HO conversion JeepDude87YJ YJ Wrangler Technical Forum 6 07-09-2007 11:42 AM
tj tie rod conversion clyderains TJ Wrangler Technical Forum 2 06-30-2007 06:47 PM
thread from the siping thread....didnt wanna hijack.. 0IIIIII0 TJ Wrangler Technical Forum 3 01-20-2005 12:55 PM
