My YJ to CJ-9 Conversion Thread - Page 12 - JeepForum.com
post #166 of 180 Old 11-28-2012, 09:37 PM Thread Starter
JeepsOLot
Hasn't been alot to write about. I did swap a sport bar for my family bar to Mean Max for one of his customers. The sport bar was off a CJ, as it doesn't have provisions for the windshield spreader bars. Doesn't look too bad, at least at night.
I swear that there is more CJ metal on this Jeep then YJ metal!!
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #167 of 180 Old 03-14-2013, 03:04 PM Thread Starter
JeepsOLot
Thanks to a friend at work, I got a set of Bestop sport bar cover and padding for free! It was never even installed before!
I also got a new trail cover, since my old one only fit the family bar.
Jerry
post #168 of 180 Old 03-14-2013, 06:27 PM
Louie4
Very nice. Your jeep is definitely vintage.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #169 of 180 Old 03-14-2013, 06:43 PM Thread Starter
JeepsOLot
I often wondered what would have happened if I just bought a late model CJ7, and put a 4.0/AX15 drive train in that. Probably would have looked the same!
Jerry
post #170 of 180 Old 03-17-2013, 10:04 AM Thread Starter
JeepsOLot
Got some pics outside of the carport this morning, with the roll bar padding.
Pics of the roll bar.
Jerry
post #171 of 180 Old 03-17-2013, 05:01 PM
captainauti
looks sweet. i just finished painting my hood and grill to the front clip swap. thinking of tube fenders. your jeep def. looks vintage. nice job.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #172 of 180 Old 03-17-2013, 05:22 PM Thread Starter
JeepsOLot
Thanks! There are a few people I've met that would like to do the swap and use CJ tube fenders. I saw one that was done like that, and it looked pretty sweet. I think I've done all of the retro stuff I going to do with it. Now, I need to work on the body, and the drive train rebuilt, and it should be good to go.
Jerry
post #173 of 180 Old 03-30-2013, 01:59 PM
ldso
Haha ditto, prepped and got the first coat on today. I am running a 1965 CJ-5 hood and grille with the YJ fenders.
I'm glad people will see the hood from the side and not the top. Hope my second coat does wonders
I really like the way both of yours looks. I've built my YJ too much to change rigs, but I like the CJ look better.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #174 of 180 Old 03-30-2013, 05:07 PM Thread Starter
JeepsOLot
How is that '65 hood working? I know it's a few inches shorter then the later CJ's.
Jerry
post #175 of 180 Old 03-31-2013, 06:42 PM
ldso
Jerry
I finished painting and clearcoating. I'll put up some pics once I start the swap. From what I have read, other guys have used CJ-5 hoods on YJ's. But not sure what years they used.
I'm really jonesing to start the swap, but I have a trail ride this coming Saturday. Have to make sure I'm ready for the ride. We'll see how ambitious I get this week.
I have the 2.5L, so there is a lot of room to move the grille back. My fenders are rusty, so if need be they could be modified to make things work.
ldso is offline
post #176 of 180 Old 03-31-2013, 09:21 PM
skyj
That '65 hood is going to be about 6" shorter than your YJ hood. They went to the longer nose in ' 72. You have the 4cyl so you might be able to pull it off without clearance problems. I went with a '52 grill and a '84 hood. The grill took a lot of work to mount but it was all worth it in the end.
Sorry to jack your thread jeepsOlot
build thread:
skyj is offline
post #177 of 180 Old 04-01-2013, 05:09 AM Thread Starter
JeepsOLot
That's cool, nice to see other conversions!
Jerry
post #178 of 180 Old 04-01-2013, 11:20 AM
ldso
Thanks for the info skyj, I will get out the tape measure before I go any farther with using this hood. 6" sounds like a lot... My paint job is purdy tho...
Good looking conversion skyj, the flat fenders work well with a CJ grille I think.
jeepsOlot hope it's cool chatting in your thread, these Jeeps are inspiring.
edit: found this on the internet
CJ-5/7 hood. 1972-85: 99cm / 38.97 inch
CJ-5 hood ---- 71: 88cm / 34.64 inch
So about 4" shorter according to this Norwegian Jeep dude http://www.jeepclubnorway.no/smf/index.php?topic=77.0
So maybe my '65 hood is the same length as the other pre-72 ones.
ldso is offline
post #179 of 180 Old 04-04-2013, 02:32 PM
ldso
Got my parts painted up, and picked up the hardware I need. Need to fab some brackets, I have a good idea of what measurements will be.
ldso is offline
post #180 of 180 Old 06-29-2013, 12:25 PM Thread Starter
JeepsOLot
Hey, Idso, just thought of something. You might have to trim the grille more on the drivers side then I did from to clear the PS lines coming out of the PS pump
Jerry
Anyone used the AA AX-15 conversion kit? OneCleanYj YJ Wrangler Technical Forum 0 04-09-2008 11:04 AM
Dash Led Light Conversion Thread 'B'wigstrailrig TJ Wrangler Technical Forum 3 09-21-2007 06:11 AM
5.0L HO conversion JeepDude87YJ YJ Wrangler Technical Forum 6 07-09-2007 10:42 AM
tj tie rod conversion clyderains TJ Wrangler Technical Forum 2 06-30-2007 05:47 PM
thread from the siping thread....didnt wanna hijack.. 0IIIIII0 TJ Wrangler Technical Forum 3 01-20-2005 11:55 AM
