My YJ Build - Page 48 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My YJ Build
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-03-2009, 06:07 PM   #706
provinT13
^^ lol yea. I just started cutting because I was bored, i'm gonna wait for my pops to help out.
2 Hands Working Do More Than 1000 Hands Praying
94 YJ Build
99 TJ Build
provinT13 is offline   Reply With Quote
Unread 03-03-2009, 06:27 PM   #707
Matt Graham
Loving the 8.8 swap. I know you are so excited to get it in. I remember working on mine like you are now and I could not wait to get it bolted in. Keep posting up the pics. You are going to feel bullet proof when you get that 8.8 in there!
2001 TJ 60th Anniv. Ed., Silver, I6 4.0, Auto, 3.25" RC Progressive Suspension lift, JKS 1.25" BL, JKS 1" MML, JK wheels (17" x 7.5") & 255/75/17 Goodyear Wranglers (32 x 10.04), SB Front bumper & rock sliders, but saving to replace them w/ Poison Spyder, H4 headlights, LED guages & interior lights.....
Matt Graham is offline   Reply With Quote
Unread 03-03-2009, 08:46 PM   #708
provinT13
See I should have waited for my dad he already told me I should have scored it meaning cut sideways. This weekend were going to cut the old shock mounts off and replace my front pipe.
94 YJ Build
99 TJ Build
Unread 03-04-2009, 10:33 AM   #709
sebastian22
Originally Posted by provinT13 View Post
(they're not the origional spring mounts so maby the shock mounts )
Those are the sway bar mounts...
http://www.explorerforum.com/photopo...5/P1000467.JPG
Try to cut sideways rather than down so that you dont damage the axle tube. I cut a line right across the middle of those mounts, they were easier to remove in 2 pieces instead of 1.
95 Black YJ
sebastian22 is offline   Reply With Quote
Unread 03-04-2009, 10:53 AM   #710
provinT13
^^ yup that's what my dad called "scoring" but I made sure not to cut into the tube.
94 YJ Build
99 TJ Build
Unread 03-04-2009, 09:20 PM   #711
provinT13
I found a good way to do it. Cut the top chunk out, then cut above the welds.
94 YJ Build
99 TJ Build
Unread 03-07-2009, 11:56 AM   #712
provinT13
I took off the soft top for the spring/summer and put on the bikink top. It started snowing this morning so I went and got a windjammer. I still need in screw down 1 more channel on the drivers side. I'll be getting a deck dust cover in 2 weeks when I get paid again.
Still a little gap but it's better then with no windjammer at all
94 YJ Build
99 TJ Build
Unread 03-07-2009, 03:35 PM   #713
provinT13
Finished the install of all the z brackets for the windjammer, some of them were a pretty tight squeeze but I got it. Just need the duster to finish it off. Doing some camping and wheeling on the 23 so check back for lots of pics.
94 YJ Build
99 TJ Build
Unread 03-07-2009, 11:57 PM   #714
provinT13
aw I should have kept the soft top on for a few more weeks, it's gonna be cold all this week I may put on the new head pipe tomorrow or work on the 8.8
94 YJ Build
99 TJ Build
Unread 03-08-2009, 12:03 AM   #715
EK91YJ
Looks great! How do you like the windjammer?
Red 2.5l 4 inch Rubicon Express painted dash and rollbar padding black from spice
Square Headlights Member #147
Red Jeep Club #482
12 inch jl 3w3 sub in the back amped with Rockford Fosgate R500-1! Rockford Fosgate R300-4 amp powers 2 infinity 5022i in the centra pod and 2 pioneer 6x9s!
EK91YJ is offline   Reply With Quote
Unread 03-08-2009, 10:24 AM   #716
provinT13
It works great, just want the duster to finish it off. I was worried it wouldn't fit with my g.e.a.r seat covers but it wasn't a problem.
94 YJ Build
99 TJ Build
Unread 03-08-2009, 12:18 PM   #717
provinT13
Just tested it out driving 65 on the highway. It didn't flap at all and kept a lot of wind out, overall good buy.
94 YJ Build
99 TJ Build
Unread 03-15-2009, 04:28 PM   #718
provinT13
Finished grinding down the welds on the driver side sway bar mount. I need to get some more cutting disks to start on the passenger side. Re-installed the gears and shafts, and cleaned off all the stuff that was on the bench and moved the axle off the floor
94 YJ Build
99 TJ Build
Unread 03-21-2009, 11:04 AM   #719
provinT13
Got my duster on
Seems to fit a little loose though.
Also went to napa to get the rotors turned but they had to send them to another store and I can pick them up monday.
94 YJ Build
99 TJ Build
Unread 03-22-2009, 05:58 PM   #720
provinT13
Finally got the extended SS brake lines on. I almost forgot about them.
Old lines
We ran into a problem on the rear, the hard line had to be cut and re-flared, and a new nut put on because this one got chewed up by the wrench and vice grips.
Front
Rear
94 YJ Build
99 TJ Build
