02-05-2009, 12:21 AM
#661
FORMELY BIGPIMPIN
nice find, the ring is for a speed sensor for the ford speedo, if its like my motor home. my tranny wouldnt shift right when it got dirty. ther should be a pickup on the front of the housing.
and some ls have clutch pacs under the side gears. they look like an open diff at first glance.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showt...hp?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
02-05-2009, 12:22 AM
#662
FORMELY BIGPIMPIN
Originally Posted by chicalibro3
i'm pretty sure that is the tone ring for ABS.
Awesome thread btw.
and that to
02-05-2009, 11:21 AM
#663
very nice.
www.car-part.com is a nationwide junkyard search engine also.
02-05-2009, 12:19 PM
#664
Originally Posted by jbrentd
That's what I used to find it, saved me $150 or more.
Also is this part important?? It broke off but I still have the little piece. Do the calipers bolt up here? It would be facing the front of the jeep if the axle was set in, so rotate the axle 90* forward from those pics.
02-05-2009, 02:01 PM
#665
Not sure on that broken piece.
I just picked up a set of stock 4.10s and the rear is nasty. What are you using to clean up the axle?
02-05-2009, 02:04 PM
#666
That is the flange that holds your e-brake cables...its pretty important. I would keep it and see if it can be welded back on.
Here's a couple pics of what it looks like with the ebrake cables hooked up...
95 Black YJ
02-05-2009, 09:43 PM
#667
ok hopefully I can weld it back on sunday. How did you do the e brake pads?
02-06-2009, 08:21 AM
#668
The ebrake shoes are a pain in the arse! Best I can tell you, is take a couple minutes to study how the assembly works, then disconnect the springs, remove old shoes, and try to install the new ones. Theres 1 thin spring that is really easy to hook up, and a thicker one that is a PITA to stretch out and hook to the pad. Took me about 10 tries to finally get it. Just gotta have patience.
To hook up the stock ebrake cables, I followed Jedi's write up.
95 Black YJ
02-06-2009, 12:51 PM
#669
Dam u pull and pay has some of the greatest prices i've ever seen at junk yards. 12$ a piece for calipers, that's a hell of a lot better then 50$ a caliper with a 40$ core charge haha. Going down tomorrow to get them.
Sebastian22 How did you clean up the calipers before you painted them and did you need some special paint? Did you just use a drill and wire wheel?
02-06-2009, 12:57 PM
#670
Yep, just wire wheeled them, then cleaned them with lots of brake cleaner. I used regular Rustoleum, but some people use special caliper paint, or high temp / BBQ paint. I threaded the banjo bolt in and makes it off really well to make sure no paint got in there. Also masked off the rubber boots. Check the pics in my 8.8 swap thread in my sig.
PS, just call me Sebastian.
95 Black YJ
02-06-2009, 02:21 PM
#671
That is the insides of you catalytic converter (that there has Platinum $1000 per ounce in it), time for a new cat.
02-06-2009, 02:27 PM
#672
A little late dragon
Yea Sebastian I saw your pics. Unfortunatly i'm not 18 so I have to wait until tomorrow to buy the paint, red rustoleum for the calipers and black for the axle. How did you get in the smaller more cramped spots? My drill both cordless and corded spin so dam slow, the only thing that really works is the angle grinder with wire wheel. What did you spray brake cleaner on? The calipers or the axle?
02-06-2009, 02:31 PM
#673
better late than never
02-06-2009, 03:20 PM
#674
I used my cordless drill with a wire wheel attachment. I didnt really get into all the tight spots. After cleaning the calipers up with the wire wheel, I cleaned them with brake cleaner. I also used brake cleaner on the axle when I was done stripping all the paint and rust off.
95 Black YJ
02-06-2009, 09:24 PM
#675
Ok im going to get the calipers, paint, and e brake pads tomorrow. I'll be sure to get pics.
