Well, I figured it was about time to post up my very slow moving project.
This is my 1987 YJ that I purchased back in June of 2000 with 153,000 miles with various minor issues.
Over the last 10 yrs I have been busy fixing various items in no particular order:
• Starter
• Ring Gear on the Flywheel Radiator
• Ring and Pinion on the rear D35 ( I know I should not have wasted my time but I did not know that at the time)
• Sun Rider Soft top (still have the Hard top)
• Bikini Top
• Remanufactured 258 Engine (after the number 3 piston went through the cylinder wall)
• Weber 32/36 Carb
• Nutter Bypass
• 1" Body and Motor mount lift
• Syncros were going in the original trans so I picked up a $50 swap-meet Peugeot to temporarily hold off on doing a AX-15 swap (has held up for 25k miles so far).
• Homemade Sound Bar, Whiteface Gauge overlays and various other minor things.
• Rear Bumper with Receiver and D-ring tabs
• New Heater Core and Upgraded Blower motor (Definitely worth the time)
I know have over 200,000 miles on this Jeep, so the time has come to do a proper rebuild, as my current frame is rusting at the skid plate. As this Jeep is mostly my DD I wanted to try and minimize my down time with the project. So I picked up a frame that was in very good condition, and will start from there:
had it sandblasted
and just finished coating it with Chassis Saver (from Monster Paints) and top coated that with Chassis Black.
After Chassis Saver from Magnet Paints :2thumbsup:
And Top coated with Chassis Black for UV Protection
Today I ordered a Remanufactured AX-15 and NP231 from Jeep transmission shop in Montoursville, PA.
Next on the list is to order a 2.5" Lift to replace the stock springs that are in very poor condition as are the shocks. I am looking at OME, Skyjacker, RE or BDS haven't made a decision as yet (leaning towards OME).
I have to see how funds go but I would really like to put an 8.8 in, but at the moment the D35 is solid. :shhh:
I do not plan on rock crawling, and no major off roading. Plan on 31-33" tires again depending on Funds.
Well that's all for now I will post any more progress pics up as they happen, but do not expect too much until Feb.
Thanks for looking, any and all comments welcome.
• Starter
• Bikini Top
• Weber 32/36 Carb
• Nutter Bypass
had it sandblasted
