My Ultimate D30 Build, Truss,vac-disco delete, C gusset, etc. - JeepForum.com
post #1 of 43 Old 04-11-2010, 08:47 PM Thread Starter
CoverinEarth
So i've recently noticed a bent C on the drivers side of my current HP D30 under my YJ. Since the axle is already rather well built in the internal section, I really dont see the point in spending money on it that could be used elsewhere.
So the decision was made to build the ultimate D30 housing and swap my internals over to it.
I found a 91 XJ HP D30 local, complete for rather cheap. ($75)
The plan was at first just to truss and do inner C gussets and then weld my SOA perches on and go.
Then we started tearing into it and since i already run 1 piece chromoly shafts, the vaccuum disconnect is pointless. So the XJ housing also has the UCA mount cast into the vac-disco piece.
After searching the boards and finding Joe Dillards re-sleeve I decided to integrate that into my Ultimate D30 build.
The axle was dropped off friday (4-9-10)
Immediatly we tore into it getting all the unusable stuff chopped off. (Read, everything!)
Dualing grinders:
The result of a stubborn bracket:
That was the end of day 1. Today Prosonic (Nick) from JeepForum.com came over to help me finish getting it all torn down. Made lots of progress today.
Nick saying hello:
Yeah, we got carried away holding it on the stands:
This is the way the service manuals tell you to take off the pinion nut right?
Empty:
Evil has taken over:
**Daily Driven**
March 2009 JF YJ Of The Month
JeepFest 2009 Runner-up Best of Show YJ
See Dan at
for all your Fabbing needs!
And check out
for Cheap prices and quick shipping on all your Jeep needs
CoverinEarth is offline
post #2 of 43 Old 04-11-2010, 08:53 PM Thread Starter
CoverinEarth
We continued our destruction (Disassembly)
Tubes clean:
No turning back now:
O, my.
Bye bye disco:
Pieces:
Mock up for the C gussets:
Tomorrow i'll be picking up some 3" OD, 2 1/2" ID DOM tubing to sleeve the long side tube. Will also be sleeving the shortside. Then welding on the C gussets, as well as a set of BallisticFab Perches.
Then I can begin making the Truss to complete the beef of this Dana30. I know i've left out lots of technical details, but a full write-up can be done if one is wanted.
-Nick
**Daily Driven**
See Dan at
And check out
post #3 of 43 Old 04-11-2010, 09:47 PM
ritjobbie
Right on!
Ten friggin' characters!
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #4 of 43 Old 04-11-2010, 11:00 PM
Douglas S.
Cool build, you should check out Joe Dillard's disco elimination thread
1991 Land Cruiser HDJ81
Douglas S. is offline
post #5 of 43 Old 04-12-2010, 04:59 AM
ritjobbie
"After searching the boards and finding Joe Dillards re-sleeve I decided to integrate that into my Ultimate D30 build."
He's on it. How could anyone ever forget that epic thread?
post #6 of 43 Old 04-12-2010, 11:43 AM
Prosonic
Prosonic's Avatar
I have to say I'm still very surprised at how smoothly things went yesterday.
Well, aside from lighting my shirt on fire that is.
Here's to the biggest, heaviest, boat anchor of a Dana 30 that will most likely ever be built.
Mayhem in potentia
Prosonic is offline
post #7 of 43 Old 04-12-2010, 03:52 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
So far - so good, it seems.
BTW: I have not been in CA/home since Saturday. I just got back a few minutes ago. Anyway, I got your other PM's. Yep, you are correct & I was wrong concerning the 26" length. It was from memory that I gave it. I just remeasured & my DOM sleeve for the passenger side is ~21" long.
As far as other tips go - if you have the coin, I'd replace the balljoints while you're at it. I'm not sure if I mentioned that already or not. I respond to lots of PM's & I'm getting old.
I see you already have been preheating things I'd use preheat when you weld the gussets & truss onto the housing & inner C's. You probably already were thinking that, but I thought I'd mention it.
I used Tempilstick, which is a temperature indicator heat stick when I preheated the housing. Pretty good stuff & easy to use too.
Tempilstick, Thermomelt - Temperature Indicator, Heat Stick
Joe Dillard is offline
post #8 of 43 Old 04-12-2010, 04:14 PM Thread Starter
CoverinEarth
Definatly planning on new balljoints. Those ones took quite a bit of "pre-heat" just to get those ball joint nuts loose. Also will be getting new brakes and wheel bearings.
Still trying to figure out what kind of seal to useon the long side with the one-piece shaft. I dont want to have to rely on my Alloy tube seals to do all the work.
Also couldn't find any 3" DOM local. So now im trying to out-source some. Speedymetals carries it, but they want around $60 for 3ft.
-Nick
Nick
**Daily Driven**
See Dan at
And check out
post #9 of 43 Old 04-12-2010, 04:37 PM
Joe Dillard
Yea, 3" x .250" wall DOM is not always easy to get in certain areas. Luckily, San Diego has LOTS of custom fabrication/axle builder shops & they usually have it. HREW would do the trick, but I know you'd like to go the extra mile & use DOM if you can get it.
The thing about doing it in HREW would be to grind the internal weld out so that the original tube fits inside snug without being too snug.
IIRC, my local metal supply shop sold me a 3' section of DOM for ~$25-30. There are LOTS of metal supply shops here in SD to shop at, which makes things very competative for them. Sometimes the exact size tubing I'm looking for is available in their scrap bin.
post #10 of 43 Old 05-10-2010, 01:39 AM
Paraleyes
What happened to this?
Paraleyes is offline
post #11 of 43 Old 05-10-2010, 08:10 AM
Area.3.Fiftyone
Why didn't you just get an XJ housing without the disconnect?
It would have saved you a lot of work on the passenger side.
I have one here that I'm doing as well with a TNT truss and it's a whole lot easier without all that cast junk in your way.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #12 of 43 Old 05-10-2010, 08:41 AM Thread Starter
CoverinEarth
Because money wise, i got this for pretty much free and it was delivered to my work. Couldn't beat the deal.
This will be starting back up tomorrow! HAHHAA.
My BallisticFab Truss and Perches are here, the tubing is cut and ready to begin welding and all the pieces for the C Gussets are cut. Jus tgotta get the tube sleeves welded on and perches welded on before I can do the Gussets.
I'll also be dropping down to Stock (Basdtard Packs) Springs SOA, and doing tube shock hoop swith 14" Travel Bilsteins. Basically I'll have the new springs bolted to the new axle and just roll it all in at one time.
-Nick
**Daily Driven**
See Dan at
And check out
post #13 of 43 Old 05-11-2010, 06:55 PM
Area.3.Fiftyone
IMO: Just because something is free doesn't always make it the best (or even a good) choice.
If you are truly building "The Ultimate D30" ditch the disco housing and get a later model XJ housing.
There is so much more work involved in sleeving that housing, and it won't be as strong IMO no matter how you sleeve it.
XJ housings are a dime a dozen around here.
It's your rig and you gotta do what you gotta do, but still.
post #14 of 43 Old 05-11-2010, 07:18 PM Thread Starter
CoverinEarth
I don't understand how it won't be as strong. Im sorry but being sleeved with 1/4" wall DOM and a truss over it will make it 100times stronger then a plain jane XJ non-disco housing.
And if these non-disco xj hp30 housings are such a dime a dozen, why don't you bring me a free one and rop it off, then i'll use it.
I make due with what i get and honestly im tired of your "opinions" because you know what they say about opinions.
This is a build thread, not a pissing match, dont let the door hit you where the lord split you.
**Daily Driven**
See Dan at
And check out
post #15 of 43 Old 05-11-2010, 10:50 PM
Paraleyes
X2! I don't see what the point is in going out of your way to down this project like that. I think it rocks. I was looking at those gussets you have planned. Are those going to clear your spring plates?
I didn't sleeve mine, but I did box in the LCA mounts and the plate the front of the passenger's side UCA mount and put in a make shift truss from that across since I had a piece of scrap that worked.
Here's my HP30 out of my wrecked 96 XJ:
Trying to build the ultimate expedition jeep... IH8ROADZ TJ Wrangler Technical Forum 35 08-08-2009 08:34 PM
Homebrew axle truss 101 build Joe Dillard YJ Wrangler Technical Forum 15 04-03-2009 06:56 PM
Help Me build The Ultimate TJ XJ Rocker TJ Wrangler Technical Forum 32 11-19-2007 03:08 AM
Build my ultimate YJ. bayvilleYJ YJ Wrangler Technical Forum 11 02-20-2007 08:12 AM
It's Xmas....build your ultimate TJ??? RockyIV TJ Wrangler Technical Forum 31 12-18-2004 05:45 PM
