Is My Tranny Giving Up? - JeepForum.com
post #1 of 7 Old 10-02-2005, 07:10 AM Thread Starter
Six Shooter
I have been noticing recently that when I shift from 1st to 2nd gear, it has a minor but noticible grinding sound and the feel isn't smooth anymore. Anyone tell me what I should be expecting in the future because of this. The tranny is for a 4 banger and is the 5 spd.
Thanks
Six Shooter is offline
post #2 of 7 Old 10-02-2005, 08:21 AM
SwearingYeti
SwearingYeti's Avatar
Its pretty cheap to just run out to a junkyard and grab one, like 150 I paid for mine with like 70k miles. Sounds like a linkage prob maybe, or try double clutching, there was a post on it earlier this week.
1991 Red YJ - 2.5L
1988 Red YJ -304ci
1989 OD XJ- 4.0L
SwearingYeti is offline
post #3 of 7 Old 10-02-2005, 08:42 AM
yesterdaylight
mine does this also. i just double clutch it if i'm in a hurry, or if not i just sort of -=-=-=-= it very gently to allow the synchro to spin up and it doesnt grind.
Green Jeep Club Member #172
Low Output 4 Cylinder Jeep Club Member # 23
Green 1995 4 Banger
If only my pocket was as green as my Jeep :D
yesterdaylight is offline
post #4 of 7 Old 10-02-2005, 09:19 AM Thread Starter
Six Shooter
Thanks...I did note that if I allow more time to shift it doesn't grind. All other gears I can shift at normal pace. I get the sense that I should perhaps start looking for good used one for when it does fail.
post #5 of 7 Old 10-02-2005, 07:45 PM
SwearingYeti
Good idea and good luck with it
1991 Red YJ - 2.5L
1988 Red YJ -304ci
1989 OD XJ- 4.0L
post #6 of 7 Old 10-03-2005, 10:19 AM
4bangersRme
same thing happend with mine cept my tranny is brand new....i let my girlfriend drive my jeep and when i got it back second gear was terrible..... i think its a syncro problem, its probley in a million peices drain you tranny fluid and it could tell you alot
4bangersRme is offline
post #7 of 7 Old 10-03-2005, 04:05 PM
jonnyri
jonnyri's Avatar
yeah, the earlier post was me...
http://www.jeepforum.com/forum/f12/transmission-issues-197031/
haven't had time to dig into it - only when it's cold do I have to double clutch to get it into second. All other gears are fine - I've been told (in no particular order):
1 - syncros (probably worst case)
2 - worn linkage
3 - bleed the clutch - mechanic friend said that he did one just like mine and it's been two years since the bleed - don't know why but it affected second gear
4 - swap for synthetic fluid
5 - let it warm up before you drive - which is my current solution - once it's warmed up it's fine. But, living in NE means that winter's going to suck if I don't fix it first!
Dirty, rusty, banged up YJ.
OSJ / NEA Delegate
jonnyri is offline
i am giving away a membership, RnEmOvr Wrangler General Discussion 0 10-07-2008 07:43 PM
so im giving up mtn_wrangler YJ Wrangler Technical Forum 42 09-04-2008 09:59 PM
Dad giving me '88YJ swa88yj YJ Wrangler Technical Forum 23 07-26-2008 03:29 PM
giving the 4.2 some power? bigrobby YJ Wrangler Technical Forum 10 02-05-2008 06:45 AM
'97 still giving me problems MadDawg TJ Wrangler Technical Forum 16 12-02-2005 05:49 AM
