Is my TH400 fried??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Is my TH400 fried???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread Yesterday, 01:32 PM   #1
billy_butler
I have a YJ with a SBC/400. "D" has stopped working. I can burn out with the shifter in 1st, 2nd, and reverse. If I put it in 2nd it shifts from 1-2 just fine. I put it in drive it just kinda slips and creeps along no matter the RPMs. I did fill it with lake water a few months ago but I flushed it and its been running fine the plug has fuzz but no chunks and the fluid is not burnt. I changed the modulator, fluid and filter. Someone please be a TH400 guru and tell there is a little ball stuck in the dang dole valve body somewhere and that the friggin lake water didn't catch up with me...
billy_butler is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 02:36 PM   #2
1320yj
Probably fried. Water and automatic transmissions don't mix even for a short period of time. Water delaminates the friction material on the clutches. Looks like time for a rebuild.
1995 2.5 5Speed SOA 33x12.50 Mud Rovers
1320yj is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:16 PM   #3
Old4X
1990 CJ7
Have you dropped the valve body to see if all the spool valves are free?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:31 PM   #4
The_Goob
Hell on Wheels
The_Goob's Avatar
Maybe im just numbed from my current vehicle problems, but even if its toast so what? those things are a dime a dozen get another one. 350/400/700r4 all plentiful and easy to get and will bolt up
-- Hell on Wheels --YJ Build Thread
-April '14 YJOTM-
The_Goob is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:09 PM   #5
billy_butler
Not easy to get in Sicily buddy
Unread Yesterday, 08:23 PM   #6
Old4X
1990 CJ7
Especially the 2-3 shift valve in the valve body, and the 2-3 modulator valve .
I know the CJs with the TH400 used an electric kickdown switch, but I don;t remember if they also had a vacuum modulator. If yours has one, check and see if there is fluid in the vac line when you pull it off the modulator. If so, your diaphragm is ruptured and you need a new vac modulator.
