#1 | |
My taurus fan install
Hey everyone I just replaced my radiator and figured while I was under the hood I'd shoot some pictures of my new taurus fan install. My other electric fan didn't pull enough air so I got a taurus fan for cheap off of ebay. I'm really pleased with it and it cools extremely well. This was probably one of the best not so expensive mods I've done in a while!! I ended up using an 85 amp continuous duty relay I got off the internet for $40 shipped so I could be sure it wouldn't burn out. I ran that/the fan off of a thermostat switch I got from autozone. I used 8 guage wire running from the battery to the relay and from the relay to the fan(and grounding the fan), 12 gauge from the temp switch to the relay, and smaller stuff for everything else drawing less current.
![]() ![]() ![]() ![]() ![]() ![]() Obviously there is a wind chill on the sensor but you can see/hear how much air the fan pulls. ![]()
"Lock tite!! Mans best friend cuz your dog won't keep your jeep from falling apart." Last edited by Berb_15; 03-20-2008 at 09:40 PM.. |
#2 |
My setup is a lot like that, but I kept blowing fuses and switched to a 40 amp circuit breaker. Works great.
You can't teach an old dogma new tricks. |
#3 |
Where did you have your fuse? I didn't run any except the on that came on the thermostat switch. I figured the stuff I had was heavy duty enough but it would probably be a good idea if I threw one in there. and where did you get the circuit breaker from? Thanks
"Lock tite!! Mans best friend cuz your dog won't keep your jeep from falling apart." |
#4 |
I got it from Carquest for around $7. I put it between the battery and the solenoid.
#5 |
ISO 9001 Compliant
looks nice. mine was like that, crazy close to the water pump. Did you trim off the plastic lugs that the fan motor sits on? That gained me about 1/4 inch. I later added a 1" BL which solved the closeness problem.
I used two relays, one each for high and low. used the temp controller on the low side and switch for full on high. Are you using the radiator probe temp sensor? For that I made the hole a little oversize and packed it full of jb weld to hold it in place. works great and no fear of it rattling around and wearing a hole thru the fins. cheers
. . "The right to be heard does not necessarily include the right to be taken seriously." —Hubert Humphrey . If you live within wheeling distance of San Diego county, click here |
#6 |
Yea it's very close, I just shaved some of the shroud off to get it to fit perfect. I'm not even using my low setting, It's probably overkill but I didn't feel like messing with switches for the time being(I just needed a fan!) and I figured I couldn't go wrong with the high setting. What amperage relay did you use for the low, a 40ish? If I still have the Jeep in the spring I probably will hook both settings up.
#7 | |
ISO 9001 Compliant
#8 |
I was thinking about doing that with a 50 amp heavy duty toggle switch, that's probably what I'll do to save money and hassle
#9 |
Um.....
I would do my best NOT to run 50amp (or any high current) thru the firewall... One scrape on the insulation and with the large fuse at the feed end (the battery) and there could be fire damage inside the cab... It happens... people that have foregone relays for lights will tell you... and have later put in relays after the smoke and burnt wires... Ted...
Veni... Vidi... Vici....TOGA!!!!!! 1993 YJ Wrangler (now with the youngest daughter) 1997 TJ Wrangler Rubecon (yep RUBE CON) 2005 TJ Wrangler X (now with the oldest daughter) 2006 KJ Liberty Renegade (the work vehicle) 2007 MK (or is that mmmmmk?) Compass Limited (the wifes 4x4 daily driver) |
#10 |
ISO 9001 Compliant
x 10,000 on the relays. make sure to get ones rated for continuous duty. Not expensive.
got mine here. http://www.solarseller.com/dc_photoswitch__dc_timer__voltage_controlled_switc h_dc_relay.htm#12_volt_75_amp_bosch_power_relay
#11 |
I used this soleniod. It's 100 amp continuous and was $25.
http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?xi=xi&ItemId=1611784827 |
#12 |
that install looks great, I have to do this. . . someday
#13 |
After everything was said and done, do you feel you gained a noticeable difference in performance/horsepower? I have a Taurus fan conversion on my never ending list of Jeep mods to do and am curious the results are that remarkable.
How long did it take how much do you have invested in the entire conversion?
Welcome to my midlife crisis. ;) '89 YJ Wrangler, 4.2L, MC2100 Nutted Carburator |
#14 | |
ISO 9001 Compliant
Total investment is probably, $125 including an upgraded alternator.
#15 | |
Taking my time and doing it nice and clean probably took 2 hours? But like I said I took my time and I'm very meticulous when I work on my vehicles...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
