My tail light is on it's own program - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My tail light is on it's own program
July 4th Sale Event! and Yes, We're Open!Metalcloak: Celebrate Freedom with Free ShippingThe Cure for your Tie Rod Roll!
Unread 10-11-2002, 11:38 AM   #1
MaryB54
Ok, right rear tail light- (if your looking at it from the back). It was out at first, so I replaced all the bulbs. After a new fuse for the turn signals, my '89 once again makes the "ticking" noise when my left turn signal is on, but when the right one is on- nothing. Now that's the least of my problems. The best part is that my right light is now on but it's on high- like when your turn signal flashes brighter- it's like that permanently. The turn signal indicator (on the dash) just comes on, but doesn't flash and my front turn signal stays on too- no flashing. When my lights are on that right tail light is always brighter than the left. But get this- when I brake the right tail light gets dimmer like it's supposed to be all the time. The left tail light and front turning light are working normally. I am so frustrated at this point, I don't know what to do. Can anyone help me??
MaryB54 is offline   Reply With Quote Quick reply to this message
Unread 10-11-2002, 11:43 AM   #2
NaeKid
JF Administrator, eh?
NaeKid's Avatar
You might have the brake light in backwards .. its a two-pole light .. flip it the other way, and try again ..
Let us know what happens ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver 2006 TJ Unlimited, zombie ready as the daily-driver
- - - - - - -TEOTWAWKI- - - - - - -
NaeKid is offline   Reply With Quote Quick reply to this message
Unread 10-11-2002, 05:57 PM   #3
MaryB54
thank you
Thank you so much! It was so simple. Funny thing is for how many times I've pulled that bulb out, and played around with the wiring and such, I never turned the bulb the right way. Once again thank you for solving the problem that has been bugging me for a while now. Chet's all better now- thank you !
"Chet"~ 1989 Wrangler YJ
4.0L Manual
166,800 miles and counting
Personal Peeve: Girly girls in automatic Jeeps
Unread 10-11-2002, 08:58 PM   #4
NaeKid
NaeKid's Avatar
Not a problem ..
BTW: What's with girly automatic Jeeps? MY Jeep is automatic.
