is my t-case still working? - JeepForum.com
post #1 of 11 Old 05-01-2011, 10:18 AM Thread Starter
venturaf
i have a 90 yj and yesterday i went up to go play around in the snow. i pulled up to the snow put it in 4lo and got ready. i could feel the pull of 4lo on the street but soon as i hit the snow front tires wernt pulling just spinning the rear. why is that?
venturaf is offline
post #2 of 11 Old 05-01-2011, 10:54 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Your front axle disconnect may not be working.
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 11 Old 05-01-2011, 10:56 AM
jeepinvader
x2 on what Max said.
Free Chuck!
jeepinvader is offline
post #4 of 11 Old 05-01-2011, 10:58 AM
moonshinefuel
Probably starting with the simple things like vacuum line problems, visual inspection then go from there. On my 95, I found the lines were damaged under the battery tray. So, probably looking at this type of thing first, then start looking elsewhere after that. It is less likely the t-case, and more likely vacuum, or the shift fork mechanism in the front axle. A couple of links. Found 1990 cherokee dana 30 write up, should be the same as yours I would think.
http://www.jeepforum.com/forum/f12/4...fixed-1121523/
http://www.cherokeetalk.com/forum/f6...sconnect-1102/
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 11 Old 05-01-2011, 11:26 AM
BearinNM
My 91 would have problems with the vacuum connector at the axle in cold weather (snow/ice). The plug that goes into the axle housing has two rubber vacuum connectors that can get cold/frozen and leak vacuum. The cheap fix to fix the/a leak here is to put two very small hose clamps on these two vacuum lines.
You did not state whether your 4wd light is coming on, but when you get a vacuum leak in the system the fork and collar will not slide over enough to engage the axles nor trigger the 4wd light. Vacuum should slide the collar inside, which will depress a switch on the inside of the housing to trigger your 4wd light. You can also get a broken fork which will still slide with the collar and activate the 4wd light, but the collar will not enage the axles.
Craig
BearinNM is offline
post #6 of 11 Old 05-01-2011, 11:55 AM Thread Starter
venturaf
no i sorry i for got to say that i did notice the light did not come on
venturaf is offline
post #7 of 11 Old 05-01-2011, 12:00 PM
jeepinvader
then it's probably a vacuum line. check them for cracks or breaks.
Free Chuck!
post #8 of 11 Old 05-01-2011, 12:04 PM Thread Starter
venturaf
it would be the lines that run up from the axle and just follow them to the top?
venturaf is offline
post #9 of 11 Old 05-01-2011, 12:07 PM
jeepinvader
yeah, just follow them back. it shouldn't be that difficult to spot the problem.
Free Chuck!
post #10 of 11 Old 05-01-2011, 12:10 PM Thread Starter
venturaf
ok cool ill go check that out and let ya know
venturaf is offline
post #11 of 11 Old 05-01-2011, 12:17 PM
nembudonna
If it's not a leak it's the axle shift motor. If the light doesn't come on even when it works, it's because of the stupid switch they used in that year. They never work.
nembudonna is offline
Transfer case shifter is not working (2wd/4hi/4lo) Rudinater JK Wrangler Technical Forum 14 07-22-2015 06:37 PM
Transfer Case not working in 4wd Low TheRealKTrain TJ Wrangler Technical Forum 25 09-30-2010 08:34 AM
Speedmometer not working after T-case Swap lndwarrior YJ Wrangler Technical Forum 3 05-09-2009 11:04 AM
ARB Locker working in cold weather. Compressor keep turned on, but not working hard Sparty TJ Wrangler Technical Forum 3 02-01-2009 05:31 PM
YJ 4-wheel drive not working, Issue is with Transfer case, Want to do it myself. IronFalcon YJ Wrangler Technical Forum 1 01-31-2009 02:32 PM
