My stupid question. - JeepForum.com
post #1 of 3 Old 06-15-2011, 05:16 PM Thread Starter
Islander_child
My stupid question.
Alright im in the process of replacing my CAD system with a cable posi loc system. Well i cracked the housing open on the passanger side and gear oil spewed out. Question. Where the hell do i fill it back up? I assume its at the differential but i wasnt sure if there was some separate point for the axle.
K.I.S.S. Keep It Simple Stupid.
Islander_child is offline
post #2 of 3 Old 06-15-2011, 05:17 PM
MoparFreak69
It just comes from the fluid you put into the differential. There is no seal on that side so it splashes/flows out of the differential into the axle tube and lubricates the CAD parts.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #3 of 3 Old 06-15-2011, 05:24 PM Thread Starter
Islander_child
thats what i figured thanks
cad , dana 30 , gear oil , posi-lock
Stupid Stupid Question.... Axle ratio for 33" tires w/ 4.0 I6 5 speed TheBandit TJ Wrangler Technical Forum 4 01-27-2011 10:49 PM
97 2.5 Exhaust Manifold Question - Probably a stupid question. F4ion1 TJ Wrangler Technical Forum 7 07-23-2010 08:13 AM
Exhaust guard? stupid stupid stupid mrcrwly JK Wrangler Technical Forum 10 05-15-2009 04:44 PM
Stupid stupid stupid Hi Lift question Ichytriggrfingr YJ Wrangler Technical Forum 11 04-23-2006 12:18 AM
Stupid question about something stupid I did WheelinTJ2004 TJ Wrangler Technical Forum 2 09-29-2005 03:15 AM
