My steering's gone crazy!! - JeepForum.com
post #1 of 17 Old 04-16-2010, 11:08 PM Thread Starter
Jeeperez
Okay so heres the deal,
I decided to remove the front track bar on my 93 Wrangler. While I was at it, I removed my swaybar since I have heard so many people just scrapping that too. Well the removal went very well, the bolts came right off and both bars were removed in about an hour. I took it for a test drive to see the difference and I barely have control of the jeep!!
There is a lot of play in the steering wheel and bump steer seems to be just throwing the whole thing out of control. Its practically undrivable. Do I need to have the sway bar in place?? None of the steering components were touched
The jeep is on stock springs, with 1.5" shackles and stock 28" tires
Matt
Originally Posted by daverubino View Post
Sell your YJ???? Why would anyone do that. You dont sell YJ's you just keep them until they become parts heeps for your next one.
Jeeperez is offline
post #2 of 17 Old 04-17-2010, 01:58 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by JEEPEREZ View Post
... removed my swaybar .... I barely have control of the jeep!!.... Its practically undrivable......
Answered your own question didn't you ? You need a front sway bar. Look into some sway bar quick disconnects for off-road use.
CJ7-Tim is offline
post #3 of 17 Old 04-17-2010, 02:36 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
My guess is that you have worn components within your suspension & steering system that are directly related to the poor manners you are experiencing now.
Thousands upon thousands (maybe hundreds of thousands) YJ owners ditch the items you have with no issues whatsoever.
Joe Dillard is offline
post #4 of 17 Old 04-17-2010, 03:28 AM
Barrio
im sure that number is in the millions by now.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #5 of 17 Old 04-17-2010, 07:14 AM
dustinsspace
Please let me know what you find out with this because I am thinking about removing mine as well and would like to know what causes these issues?!?
dustinsspace is offline
post #6 of 17 Old 04-17-2010, 08:42 AM Thread Starter
Jeeperez
I thought that you could drive without one, almost everyone here on the YJ forum says you can
Could worn out springs cause it?
Thats what I thought!
I will let you know as soon as I figure this out
Matt
Jeeperez is offline
post #7 of 17 Old 04-17-2010, 09:03 AM
Apollo12227
Threw my swaybars and trackbars front and rear in the trash... No problems here.
Apollo12227 is offline
post #8 of 17 Old 04-17-2010, 09:18 AM Thread Starter
Jeeperez
Since a majority of people don't have problems, is my suspension indeed so gone that it won't hold by itself?
Would the shock on the tie-rod do anything to help it? It looks like it could be worn out
Matt
Jeeperez is offline
post #9 of 17 Old 04-17-2010, 10:24 AM
TrynPas
same here......only notice it a long sweeping curves on the freeway while I'm doing 65 or so. Kept mine for awhile, but they're scrap metal by now. I just added new RC 4" lift springs that are pretty firm, maybe your stock ones are worn out.........upgrade time.
TrynPas is offline
post #10 of 17 Old 04-17-2010, 10:50 AM
trw
2011 JK Wrangler
you need a swaybar because your XJ has front coils, he does not because his YJ has front leafs.
OP, sounds like you could use some new leafsprings, shackles and bushings.
I tossed my trac bars and swaybar years ago, haven't missed them since.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #11 of 17 Old 04-17-2010, 10:58 AM
hesserdude07
first thing i did when i bought my jeep was throw away the front and rear track bars, and the front sway bar. i DD mine and have never had an issue. Sounds like you need to look at ball joints / tie rods. i put in all new spring bushings when i dropped my stuff.
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #12 of 17 Old 04-17-2010, 11:11 AM Thread Starter
Jeeperez
I am getting an RC 1.5" leaf spring kit from a friend for free the first week of May, so the springs and shocks will get replaced.
I also put my swaybar back on to notice any difference..and the steering is still sloppy! The only thing thats off now is the front track bar
Matt
Jeeperez is offline
post #13 of 17 Old 04-17-2010, 01:12 PM
BondoBbad
That shock on the tie rod is called a steering stabilizer and it will definitely help with bump-steer. Sway bars don't do anything but help control body roll when cornering, shouldn't really affect your steering much. And the Trac bar is just supposed to keep you axle centered under your jeep but if your u-bolts and shackles/bushings are all in decent shape you shouldn't need you trac bar or your sway bar. My Jeep can be a handful at times but I just accredit that to the big tires that are worn out and scalloping pretty bad.
If I were you I would crawl under the jeep and check for loose bolts or worn parts.
BondoBbad is offline
post #14 of 17 Old 04-17-2010, 01:13 PM
BondoBbad
If I were you I would crawl under the jeep and check for loose bolts or worn parts. Another thing you could try is to tighten your steering box up a little. But that will only help take extra play out of your steering. Do a search on the forum and you will several good write ups on it.
*edit* Sorry, about the doublepost. I meant to hit the edit button and hit the quote button accidently
post #15 of 17 Old 04-17-2010, 04:19 PM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by trw View Post
you need a swaybar because your XJ has front coils, he does not because his YJ has front leafs..
I still have the sway bar on my mildly lifted CJ-7 (and the XJ), quick disconnects are inexpensive and I simply disconnect for the 4x4 trails. The CJ is more stable with the sway bar connected for pavement driving.
Lift kit leaf springs and custom leaf springs are firmer than stock springs (especially worn out springs) and in that case you may be able to get away with no sway bar, but I wouldn't suggest to anyone else to drive without a sway bar.
CJ7-Tim is offline
Crazy CJ Syko3599 Wrangler General Discussion 2 03-15-2010 10:32 AM
This is CRAZY!! gtoneill JK Wrangler Technical Forum 5 12-29-2006 05:40 PM
Am I crazy? admar2 YJ Wrangler Technical Forum 3 08-01-2006 04:23 PM
Going crazy? DrD TJ Wrangler Technical Forum 26 08-04-2005 09:23 AM
Crazy snorkel idea! Too crazy? Bryan_16 TJ Wrangler Technical Forum 13 11-06-2002 09:04 AM
