My "SOA And Other Stuff" Build - Page 2 - JeepForum.com
post #16 of 38 Old 03-20-2011, 07:26 PM
YJ89jeepTX
did u weld the front spring perch parallel to stock or did u drop the pinion a bit to get more caster?
YJ89jeepTX is offline
post #17 of 38 Old 03-20-2011, 07:49 PM Thread Starter
notmyj
I welded them so that I have factory angles. It doesn't wander any more than expected on 35's with 18psi.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #18 of 38 Old 03-20-2011, 07:52 PM
YJ89jeepTX
wouldnt welding them parallel to the stock perches keep the angles at factory?
post #19 of 38 Old 03-20-2011, 11:25 PM
Douglas S.
It would keep your caster angle at factory.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #20 of 38 Old 03-27-2011, 08:15 AM
YJ89jeepTX
how did u all use the spring plate for the shock? mine doesnt seem to fit
post #21 of 38 Old 03-27-2011, 10:52 AM Thread Starter
notmyj
I dont think I used the metal sleeve in the shock bushing. Try removing it. Also, some shocks come with two different size metal sleeves. Be sure you are using the large one. If it doesn't fit, just run it with out the metal sleeve.
notmyj is offline
post #22 of 38 Old 03-27-2011, 01:04 PM
YJames90
YJames90's Avatar
I drilled a hole and ran a grade 8 bolt throigh the mount as a pin. Its been holding up rock crawling for a year
YJames90 is offline
post #23 of 38 Old 03-27-2011, 01:53 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
I recognize that 8.8 spring plate. I am still sprung under and cut my spring plate to reuse the shock mount but welded it onto the axle.
To view the NEW
click here!!!
tobias94yj is offline
post #24 of 38 Old 03-27-2011, 01:56 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
notmyj are going to do anything on the rear because I notice you rub your flare. it looks like that is still the stock yj flare. I love the tube fenders on the front. I am planning out some tube fenders all the way around on mine. anyway love your yj it looks great.
To view the NEW
click here!!!
post #25 of 38 Old 03-27-2011, 08:00 PM
YJ89jeepTX
hey james and not my what are ur read drive shafts and pinion angles? mine is set at 27* and 25*, seems a little steep to me.
post #26 of 38 Old 03-27-2011, 10:39 PM Thread Starter
notmyj
Not really sure what I set it at. I was less concerned with the numbers and more concerned about getting the drive shaft pointed correctly.
Here is the diagram from Tom Wood. As long as it looks like this, you should be good. Just be sure you have enough oil in the diff to ensure the pinion bearings are getting oil. I managed to stuff 4qts in my 8.8.
It currently is the factory YJ opening. The PO installed the corner armor to the tub and I am being indecisive about what armor I am going to replace it with. I am waiting to get new armor with a TJ opening then I am going to cut the body to match the opening in the new armor.
notmyj is offline
post #27 of 38 Old 03-27-2011, 11:08 PM
YJ89jeepTX
ya thats how i set mine up too...but dropped it 2 degrees less, those were just my numbers and was curious what others are running with their cv shafts,.
post #28 of 38 Old 03-28-2011, 09:19 AM
giggityjeeper
Yes, you probably saw my set up
Jeep looks nice !
most ppl doing SOA do this do they not, its just he old sway bar connects, did the same thing worked perfectly if ya have no more sway bar...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #29 of 38 Old 03-28-2011, 01:54 PM
jbeebe
any updates on how you got out the old t-case skid bolt that you had a problem with in the beginning?
jbeebe is offline
post #30 of 38 Old 04-02-2011, 11:07 PM
YJ89jeepTX
any of u get any steering shake or "death wobble" after the install?
A rookie build journal TJ 2000 "El Cheapo" Greenturd TJ Wrangler Technical Forum 0 01-26-2009 10:31 PM
White "Stuff" on shifter arm? denwagh YJ Wrangler Technical Forum 6 05-18-2007 11:59 AM
What's the best stuff to use to "Linex" the Interior Floor? 04TJSportRed TJ Wrangler Technical Forum 4 03-03-2007 12:41 PM
"Heavy Duty" Springs listed on build sheet? IAJack TJ Wrangler Technical Forum 2 11-01-2005 05:53 AM
Will 15x10" wheels with 3 5/8 bs stuff with 4" of lift? ryan_289 TJ Wrangler Technical Forum 3 03-02-2005 08:27 PM
